Help me stop worrying !!!! PLEASE!
Old 03-11-2007, 07:20 AM
Lou Colmo's Avatar
Had a P0303(Misfire Cyl.#3) code a few weeks back (CEL was flashing then went solid) Re-changed plugs(Autolite APP104) and wires(only 2 months old) still had misfire. Replaced both coil packs and had injector cleaning done, still had problem . Then I found a bad injector on cyl.#2,Replaced and truck ran better but not great. Pulled the # 2 plug and it had white ash on it(Guessing detonation?)Replaced plug and it ran great for 2 days then the miss came back. Now the # 1 injector went bad an this plug has the same white ash on it. Wouldn't run good until I replaced that plug. Now it's running great. I guess my ? is the lean mix causing this white ash.
Old 03-11-2007, 01:19 PM
Bluegrass's Avatar
You have something in the gas.
Drain tank, replace filter and refill with known good gas.
Ash as i know it does not come from running lean or rich. It's already something in the gas causing (deposits).
That's why you get temp correction until it happens again.
Old 03-11-2007, 07:10 PM
Lou Colmo's Avatar
Just put on a new fuel filter and filled up with fresh gas.The forum won't let me post a picture.Put around 100 miles on it, so far so good.
Quick Reply: Help me stop worrying !!!! PLEASE!
