What have you replaced????
Old Mar 3, 2007 | 04:43 PM
nubuck83's Avatar
Originally Posted by hcmq
99 5.4 180k 4x4 bought new
brakes all around (3 times in front)
idler arm twice
alternator
intake gasket
2 cops
starter solenoid
both upstream 02 sensors
temp potentiometer (sp?)
IAC
rear diff speed sensor
These are the only things I HAD to replace because of a code or other problem.
How did you find out your solenoid went bad? Was that one of the code's that told you?
Old Mar 3, 2007 | 05:04 PM
hcmq's Avatar
No code for the solenoid. the truck wouldn't start. I hooked a remote starter to the solenoid and she fired right up. $11.00 part 3 years ago.
Old Mar 3, 2007 | 08:00 PM
Steve83's Avatar
There's not a part on my truck that hasn't been replaced at least once, except MOST of the frame, and the transfer case (which has been removed several times). I have no way of knowing how many miles are on it since I've changed the odometer at least twice, but the current engine has at least 350K with no rebuild. I'm guessing the t-case has over 400K.
Old Mar 3, 2007 | 09:12 PM
BLUE20004X4's Avatar
Mine's a 2000 4x4 off road reg cab flareside with a 5.4 auto and 3.55 rear l/s. Here's a list off hand of replacements:
-Tie rods, tie rods, oh yes, did I mention tie rods? I've replaced the driver side 2 and one on the passenger side is going, so both will be replaced. Get greaseable ones.
-Ball joints, the lower ones on both sides.
-Radiator 2 times.
-Thermostat once.
-IAC, got tired of constantly cleaning and thaught it was whistling.
-Belt, just because it was skanky lookin.
-Battery, was loosing go go juice.
-Fan, replaced for e-fans.
-Plugs, routine stuff considering mileage.
-Front pump seal (warranty) on tranny.
-Pinion seal (warranty) on rearend
-E brakes were cracked so it failed safety, I've since replaced all hardware too.
-Blendor motor went kaput.
-Wiper/turn signal arm (was getting those ghost wipes)
-Odometer fix.
That's about all I can think of, hope it points you in areas to keep an eye on. Alot of this stuff was just peace of mind for me, but in over seven years and 180 000 plus km's, that's cheap sh-t and not alot really, just preventative. The tie rods were a surprise, literally
Old Mar 3, 2007 | 09:40 PM
worland's Avatar
My '97 SCab 4.6L has about 166,000 miles on it. Had all kinds of OEM spark plug problems at first, but has been rather reliable for the last 80,000 miles.
OEM spark plugs blown X12
Plug wires
Side view mirror motor (driver's side)
Windshield leak
Rear glass leak
DPFE X3
EGR
Battery
Shocks
Brakes
Old Mar 3, 2007 | 10:35 PM
Klitch's Avatar
Originally Posted by nubuck83
What major problems have you had and what have you replaced to keep your truck livin on a little longer?? My 97 f150 has 156,000 mi and I just replaced the u-joints and the ball joints on the front end? How about you? I want to know what I will be changing in the near future.
144k- 185k. water pump, radiator, radiator hose, plugs n wires (duh), starter, plastic speedometer drive gear, alternator, balljoints, wheelbearings - front, some tie rod ends, rotors, DPFE sensor, idler and tensioner pulleys. i think thats it for the had to replace parts.
others for fun- gears, shift kit, suspension, and soon, 5.4lightning swap. yeargh
Old Mar 3, 2007 | 10:46 PM
00Ford4X4's Avatar
I have had 2 COP's replaced
Serpentine belt and tensioner
Both Door lock actuators (those were fun changing)
Still has original battery
Old Mar 4, 2007 | 08:24 AM
Klitch's Avatar
lol original battery. too bad i have never seen a battery last much more than 7 years on this property. thats pretty neat tho
Old Mar 5, 2007 | 09:07 AM
schudel5's Avatar
The build date on my truck is January 1997 and I just changed the original battery January 2007...laster 10 years exactly!
My 97 F150 XLT Supercab 4x4 with 95,000 miles Iv'e changed the following...
1. Pitman arm (replaced with a greasable type)
2. Both front stabilizer bar links
3. Battery
4. Multi-function switch
5. Transfer case shift motor
Obviously normal replacement items like belts, hoses, brakes, filters are not listed.
Old Mar 5, 2007 | 09:08 AM
schudel5's Avatar
The build date on my truck is January 1997 and I just changed the original battery January 2007...lasted 10 years exactly!
3. Battery
Old Mar 5, 2007 | 03:40 PM
nubuck83's Avatar
Just found out today, like so many others, that my erg needs to be replaced. Tried cleaning it but "check engine" light came back on. Add that to the list
Old Mar 5, 2007 | 03:49 PM
undeaddemon's Avatar
Smile 2003 4x4 5.4l
I just bought this truck with ~30,000. The thing runs and drives like new.
HOWEVER, the odd thing was the dealer had replaced the lower ball joints. The truck came off lease from the original owner. I have read and heard from several mechanics that having a vehicle "sit" for long periods will detroy ball joints... not sure how I fee about all that.
Other than that, the dealer showed me all the service records from the truck... just your basic stuff... brakes, oil, RV Mirror switch...
Old Mar 5, 2007 | 03:56 PM
FX4ALL's Avatar
03 Scab - 4.6 - 4x4 - auto - 62k
4 Tires @45k (rock + sidewall = bad )
Oil change + filter every 2.5-3.5k
Trans fluid + filter every 15-20k
Fuel filter 15k, 30k, 45k, 60k
Plugs, Frt & Rr diff, Transcase 50k
Colant at 30k and am changing it this weekend along with a new T-stat
Think that's about it..
~j
Old Mar 5, 2007 | 05:01 PM
97_4sixer's Avatar
My 97 F150 4.6 auto 4x4 just turned 198,000 miles saturday and here's my list of what I have replaced. With everything that has been done including oil changes I have only spent $700 in maintenance costs.
1. Multifunciton switch
2. Left front hub
3. Original starter at 187,000
4. Battery
5. Positive batter cable (due to corosion)
6. Sway bar links
7. Spark plugs and wires
An old high school friend has spent well over $3000 on his 90 full size jimmy. He has had the rearend overhauled twice. He gives me crap saying that my truck sucks. My truck has never left me stranded and hope it never will.
Old Mar 5, 2007 | 05:41 PM
jrc78952's Avatar
I have a 97 F-150 4X4 4.6L and i have had it for a little over a year now and i had to replace the front brake line at 100,500, Sway Bar end links 101,000, starter at 103,000, spark plugs/wires at 105,000, cat-back exhaust at 112,000, and now at the top of the list is a exhaust manifold leak. But over all not back all minor fixes
