big time problems!!!
Old Jan 24, 2007 | 12:10 AM
fordman164's Avatar
Angry big time problems!!!
today my engine took a dump. i have 180,000 miles on it and have not had 1 problem. yesterday i porred injector cleaner into it and today i came up a hill and the engine just quit! WTF. It sounds like some sort of air leek and as if its only running on a coupple cilenders. could this be the problem or just a coinsidence?:o
Old Jan 24, 2007 | 03:05 AM
keith97xlt's Avatar
check all vacumn lines, check your plugs, when was the last time u changed the fuel filter?? check all the tune up related things first.
Old Jan 25, 2007 | 12:39 AM
fasterhorses's Avatar
Just guessing but if you poured the cleaner into the gas tank it might have loosened some crud in the tank and plugged the fuel pump screen filter. The fuel pressure might test okay but it should fail a flow (volume) test. I hope I'm wrong cause it's a bitch to pull the tank and pump.
