Whats my towing capacity?
auto's tow more than manuals because auto's make alot more torque. but the big factor is how good are your brakes? thats what they generaly use to rate the trucks. which is why the 5.4 and 4.6 have almost the same towing capacity. because they use the same brakes.. stoppin is more important than the power to pull it.
Originally Posted by Bluegrass
Joe, I don't know if your referring to me but towing and loading are two different things.... snip
I'm with you 100% on the actual versus theoretical towing capacity numbers. My point was just that the capacities are listed in the owner's manual (which nobody ever seems to have or read anymore).
-Joe
They don't just pull these numbers out of the air...
Originally Posted by Zaairman
Ford has never made a manual tranny Screw ever. And the only 2007 availble with a stick is a V-6.
Concerning older models, I'm a little confused I think. Many people refer to their trucks as Screw's on here. I believe most folks are refering to an extended cab model of a Ford truck, however I think they are doing so incorrectly. From what I have seen, an Screw, or I presume, SuperCrew, is likely a true four-door (all doors open towards the front, no half doors). I can believe there have never been any manual tranny Super Crews. However, I personally have driven a pre-2000 (not sure exact year, wasn't my truck, but was the new body style) that was a 2 wheel drive, manual tranny 4.6 liter.
Sorry for the confusion,
Mike
Originally Posted by mrainey889
Go figure. I got all my info from F150.net. After checking the "Build Your Own" at the official FOMOCO website, sure enough as soon as you select any thing other than the v-6 in any half-ton model (yes, I know, no v-6 in the 3/4 ton's and up, but you can get a stick I believe...) an immediate change to an automatic is required. No wonder Ford keeps losing market share...
Mike
Mike
Well here is my ride... 2001 F150 4X4, 4.6 V8, 5-Speed Manual transmission
http://photos1.blogger.com/x/blogger...9/DSCF0702.jpg
http://photos1.blogger.com/x/blogger...ur%20house.jpg
