Need help with my PI Head swap!
Old Jan 11, 2007 | 01:37 AM
whitelarie's Avatar
i have a 97 4.6 that has been threw hell and back. now i want to upgrade the heads to PI Heads and i am stuck. I dont know what intake manifold would it use. anybody know if i could put PI 4.6 heads with a 01 4.6 intake manifold.
Old Jan 11, 2007 | 02:06 AM
Klitch's Avatar
i believe 99+ is PI, thus even if the intake was different the 01 intake should work with the PI heads.
but some reason i think the intake manifold should still bolt up?
Old Jan 11, 2007 | 08:33 PM
built54's Avatar
no it wont seal up, you have to have the PI manifold. I have a 2 page writeup if you want it.
Old Jan 11, 2007 | 10:06 PM
Klitch's Avatar
well i covered my base! i said even if it was different the 01's intake would be PI.
sorry, my bad i didnt realize they wouldnt seal up.
Old Jan 13, 2007 | 12:17 AM
DDan1967's Avatar
Built
Correct me if I'm wrong. But don't all F150 4.6s from 1999 and up have PI heads? Hence they have PI Intake and Exhaust manifolds.
I also think that in '99 the intake went plastic with a aluminum cross over in front for the coolant. I know the '04 is all aluminum again, not sure if that switch was made earlier than that or just for the new body style.
Doug
Old Jan 13, 2007 | 12:21 AM
built54's Avatar
Yeah, any PI manifold will work on the PI heads. 99 and up
Old Jan 15, 2007 | 12:00 PM
JASON'S98S/C4X4's Avatar
Hey, Built
I have been thinking of doing a head swap on my truck. Could you tell a differance in power after the swap.
Old Jan 15, 2007 | 12:04 PM
JMC's Avatar
JMC
25 Year Member
The 4.6 got the Pi heads in 01. Ford switched to plastic when they changed the intake. So if you have a metal intake for a 4.6 it is not a PI intake. Just look at the shape of the runner ports. Tear drop is Non Pi.
JMC
Old Jan 15, 2007 | 01:52 PM
built54's Avatar
Originally Posted by JASON'S98S/C4X4
Hey, Built
with comp cams #102500, I gained 100hp from 3k up
Old Jan 16, 2007 | 10:42 AM
holy s--t,
I had know idea the swap with cams would yield that much Horse Power. What is your H P at the fly wheel. The only problem I see with the head swap in my situation is the compression because I'm supercharged. I wonder if the PI heads could be ported enough with the use of a supercharger.
Old Jan 16, 2007 | 11:55 AM
JMC's Avatar
JMC
25 Year Member
JASON'S98S/C4X4,
The only effective way to lower the CR is to change the pistons out for deeper dish ones. You could send your non Pi heads out to get them CNC'd. I would not risk trying to enlarge Pi head's combustion chamber.
JMC
Old Jan 16, 2007 | 01:57 PM
built54's Avatar
didnt know you were supercharged, I wouldnt do it then, boost would have to be low along with timing, unless you want to run race gas...
Old Jan 16, 2007 | 02:10 PM
built54's Avatar
holy s--t,
You could say its 325hp at the flywheel. that dyno run was with my heavy tires...
Old Jan 16, 2007 | 07:34 PM
whitelarie's Avatar
still need help
hey built, i am confused i need to know what kind of intake i need to swap some pi heads on my 97 4.6 and where i could find it. or what kind of upgrade i should do with 2500$. my truck has about 143000 miles and i already have exhaust, headers, hi flow cats, programmer, high output ignition system, 4.10 gears. any opinions would help. hey built i also been looking at some turbo by sts all that sounds good, so like i said im confused. thanks
Old Jan 17, 2007 | 05:07 PM
jgarewal's Avatar
Another option
Try these heads, they are a bit expensive but they out flow the p.i.'s and you don't have to buy any other parts for the swap..
M-6049-D46 Ford racing part number.
