How much are new spark plugs?
Old Jan 4, 2007 | 09:25 PM
hsimpson180's Avatar
Hey guys ive got a 1999 4.6L V8 F150. I have 112,000 miles on it and i havent replaced the spark plugs. How much would all new spark plugs with installation be? Thanks for the help.
Old Jan 4, 2007 | 09:36 PM
jjmIII's Avatar
AUTOLITE_DOUBLE_PLAT are $4 each....figure around $100 total w/ labor (local shop, not dealer).
Old Jan 4, 2007 | 09:44 PM
tritonpwr's Avatar
Either get the OEM Motorcrafts (ONLY!) from Autozone or your dealer, then take it to the mechanic and have them installed. Figure $75-150 in labor depending on the shop. Plugs will run $35-70 depending on where you buy them.
Old Jan 4, 2007 | 09:48 PM
Dbl G's Avatar
Pricy........
http://www.briskusa.com/products.htm#premium
Old Jan 4, 2007 | 10:30 PM
Jesse H's Avatar
I spent a little over $3 for the OEM Motorcraft plugs at Advanced Auto Parts tonight.
Old Jan 4, 2007 | 11:32 PM
what plugs exactly should i get? Also, i have heard that it is best to let the dealership replace them. Is that true?
Old Jan 5, 2007 | 10:12 AM
mustangraven's Avatar
bah good old copper autolites work fine. those triple platinum snake oil plugs are bs they dont fir any differently as soon as the plag has fired a few times. just my .02
I also just did my plugs myself in my 99 4.6 f150 last week. took about 2 hours to do wasnt all that terrible. I would suggest a swivel joint and several extensions. als while your at it change the plug wires if you milage is near 100k it will save you the headach of doing it later. just do 1 plug and wire at a time so you dont mess up the order.
Old Jan 5, 2007 | 10:25 AM
Marc Carpenter's Avatar
NGK plugs are excellent for that application. Very inexpensive also...
Old Jan 6, 2007 | 09:17 AM
savage02's Avatar
I had Motorcraft platinums done at my regular shop last month for $189. Thats for the plugs and labor.
Old Jan 6, 2007 | 09:23 AM
Dbl G's Avatar
Thats about the going price from all I have heard.
Old Jan 6, 2007 | 06:52 PM
alright thanks. new plugs should last me another 100,000 miles right?
Old Jan 7, 2007 | 10:45 PM
SuperSport1985's Avatar
You might want to read up on that.
Old Jan 8, 2007 | 01:51 AM
Gene K's Avatar
Actually Platinum is harder to fire than Copper. Platinum however doesnt erode as fast.
Copper is better for performance. Platinum is better for endurance.
I cant say which brand of plugs is properly designed to work in this specific engine.
Old Jan 8, 2007 | 07:50 PM
Jesse H's Avatar
Exactly. I was about to get some copper plugs because I always had and didn't mind changing them on all my other vehicles (10 mins tops) until I realized that it'll take at least an hour on this truck. Plus being so cheap (less than $3) going with platinums was a no-brainer.
