3-valve Heads On 2-valve Block???
Old Dec 30, 2006 | 08:10 PM
  #31
Faster150's Avatar
Originally Posted by Neal
HI!... If your refferring to the intake manifold design on the MUSTANG then NO.
Any intake manifold where the TB is mounted to the very front of the plenum has problems with the distribution of incoming air to the individual cylinders. This has been a known problem. The older Camaros (IROC) had this same problem. Some cylinders run rich, others run lean. The optimum set-up is to have a top mount TB into the plenum to equalize the intake ports evenly. Ford and Chevy use this intake designs due to space restrictions under the hood in tight engine compartments.
they dont have that problem.. and the new front inlets use a lower chamber still
Old Dec 30, 2006 | 08:58 PM
  #32
Neal's Avatar
HI!... Thanks for proving my point!!!!!!! They do still have the problem. Thats why guys are still burning plugs/melting pistons with wet nitrous systems injected before the TB. Same issue our engine s have.
Old Dec 30, 2006 | 09:00 PM
  #33
ONELOWF's Avatar
http://www.livernoismotorsports.com/...t.phtml?p=1531
OUCH...
but the extra horsepower and torque should be worth it, LOL
any camshaft recomendations neal???
So, $ 7,000 for a pair of heads w/o cams? This is serious.
Old Dec 30, 2006 | 09:01 PM
  #34
built54's Avatar
that is just flat out stupid crazily expensive.
Old Dec 30, 2006 | 09:08 PM
  #35
Neal's Avatar
HI!... That is for the pair, not each! That's nothing. I paind like $5000(CAN) for my heads and cams 4 years ago.
Old Dec 30, 2006 | 09:16 PM
  #36
ONELOWF's Avatar
I looked again and it says a pair, oops. So, add the cams, and that is about the same as your $ 5,000cn set.
Old Dec 30, 2006 | 09:25 PM
  #37
built54's Avatar
o... well still thats a lot of money
Old Dec 30, 2006 | 10:55 PM
  #38
Faster150's Avatar
never heard of any problems like that happening..
Old Dec 30, 2006 | 10:57 PM
  #39
built54's Avatar
really? wow.. ive seen 3 in the past month!
Old Dec 30, 2006 | 10:58 PM
  #40
Faster150's Avatar
i paid... 705 for my heads and cams brand new last year
Old Dec 30, 2006 | 10:59 PM
  #41
Faster150's Avatar
yeh i dont see spending another 3500 on heads for little gains... just not worth it IMO if what u got works then use it till u need more. after all its going to be turbo.. if u want more air in crank up the boost
Old Dec 30, 2006 | 11:10 PM
  #42
built54's Avatar
Yep.
What kind of heads did you get for $705??
Old Dec 31, 2006 | 02:31 AM
  #43
tritonpwr's Avatar
So that's like what, $30.00 US? Pretty good deal I'd say.
Old Dec 31, 2006 | 02:36 AM
  #44
Neal's Avatar
HI!... Well since our dollar is now worth as much as yours, it's probably about $4700(U.S).
Old Dec 31, 2006 | 11:23 AM
  #45
Faster150's Avatar
Yep.
heads came from port pros in Austin ,tx and cams were brand new comp XE270's
ebay pwns all when people dont set reserves!
