Maf
Old Dec 20, 2006 | 10:32 PM
Narvous's Avatar
Maf
Do you need to take off bat cable when you clean the MAF to reset it?
Old Dec 20, 2006 | 10:38 PM
3304x4's Avatar
Well it's just a good idea to take off the battery cable when un hooking an electrical connector. Less risk of having a shocking experience
Old Dec 20, 2006 | 11:10 PM
jbrew's Avatar
Yes , you'll want to reset anyway so your PCM -retests , rereads and adjusts according to the new figures from a clean MAF.
Old Dec 20, 2006 | 11:43 PM
Narvous's Avatar
Do i just take off the neg off for 10 or put it to the pos cable?
Old Dec 20, 2006 | 11:52 PM
jbrew's Avatar
Yeah reset the KAM , touch the Positive and you can hook it right back up.
Old Dec 20, 2006 | 11:57 PM
Narvous's Avatar
Old Dec 21, 2006 | 08:09 AM
Faster150's Avatar
not but u do need to disconnect the MAF sensor like unplug it from the harness
Old Dec 21, 2006 | 09:12 AM
Narvous's Avatar
And it will not spark?
Old Dec 21, 2006 | 09:47 AM
projectSHO89's Avatar
No.
Removing KAM power while the ignition is OFF is all that is required. Simply pulling the correct fuse and leaving it out while doing your cleaning task is adequate. That way, you don't have to reprogram your radio and clock settings.
Consult the fuse layout in your owner's manual and see which one says "PCM KAM" or "keep-alive power" or similar.
Steve
Old Dec 21, 2006 | 10:18 AM
Bartak1's Avatar
Nice tip, projectSHO, I never though of that one. I alway fear pulling my battery cable because it takes me 3 days to get my radio set back up right...
