Need help - F150 started guzzling gas
Old Dec 19, 2006 | 04:57 AM
selbona's Avatar
My 2000 F150 supercab just started guzzling gas all of a sudden. Seems to be running fine except that I only get 250 miles on a tank now instead of the usual 400. Anybody know what this could be? Thanks in advance. It's got the 4.6 V8.
Old Dec 19, 2006 | 07:34 AM
projectSHO89's Avatar
Could be a number of things.
Do you have a CHECK ENGINE light?
Steve
Old Dec 19, 2006 | 07:48 AM
jbrew's Avatar
Are you the only one who drives the truck ?
Old Dec 19, 2006 | 10:04 AM
selbona's Avatar
Steve
No, the check engine light hasn't come on yet, but I'm expecting it to any day now.
Old Dec 19, 2006 | 10:05 AM
selbona's Avatar
Yeah, I'm the only one that drives it.
Old Dec 19, 2006 | 10:09 AM
beckerjs's Avatar
winter gas
Old Dec 19, 2006 | 10:37 AM
Jackal's Avatar
Winter fuel, improper orientation of the IAT, dirty MAF, failing upstream O2 sensor, faulty DPFE, plugged EGR ports (goes along with pinging) and who knows whatelse. I guess wait for that CEL and maybe try some Seafoam...???
Old Dec 19, 2006 | 11:01 AM
selbona's Avatar
What is winter gas?
Old Dec 19, 2006 | 11:19 AM
jbrew's Avatar
Sounds like a dirty air filter - I would try cleaning the MAF Sensor as well.
Change your filter
Clean your MAF sensor
Then pull your negative cable , touch it to the positive cable for a Pram reset - reconnect for learn mode . Or just disconnect both cables if your uncomfortable with touching the 2 together - leave diconnected for 10 minutes or so if you do it this way...
Good Luck
Old Dec 19, 2006 | 11:20 AM
Jackal's Avatar
http://www.albina.com/AutoFuel/oxygenated.htm
selbona's Avatar
Change your filter
Good Luck
Thanks for the help. I'll try it. _Al
Old Dec 19, 2006 | 01:09 PM
keith97xlt's Avatar
400 miles a tank??? dam! im getting around 300. ill have to try what these guys are suggesting.
Old Dec 19, 2006 | 01:15 PM
jbrew's Avatar
Originally Posted by keith97xlt
400 miles a tank??? dam im getting maybye 300. do you have 2wd??
I was thinking about that earlier. I think it's 22 or a 23 gallon tank , most I ever got was 345. That's what 16 or 17 mpg . I have a 4x4 tho and a 5.4L.
Old Dec 19, 2006 | 01:18 PM
Faster150's Avatar
Change your filter
Good Luck
disconnect the positive and touch it to the negative.. got that backwards.. if u touch the ground to the positive u will back feed power to everything and burn up alot of wires and PCMs and likely make the battery explode!.
Old Dec 19, 2006 | 01:31 PM
Jackal's Avatar
No kidding, I assumed he meant touch them together while disconnected, but wasn't clear enough about it. All you have to do is pull the neg. and flip on the lights for 10 - 15 min. then shut off lights and reconnect the neg. terminal. I use to disconnect the pos., but forgot why I switched.
