cruise control doesnt work
#46
I am excited that you can self test this stuff! I just did this for my 2002 7700. I just bought this truck and assumed it was something to do with the trailer brake unit installed. All of the brake lights work fine. Checked all my fuses.
The self test result was 3 flashes after pressing the final Set/Accel switch. Could this have something to do with the recall? Was it the deactivation switch? Any tips or places to start with this would be much appreciated!
Cheers,
James
Cheers,
James
#47
#48
#52
Wow... I would have much rather replaced the harness with it. I even gave him the part number off of mine to check and he said it's not there. My 7700 confuses the system sometimes being a crossbreed f150-f250? That's cheaper than I will be paying for just the sensor haha. I will see what they say tomorrow when I give him SW-6350. Thanks!
#53
#54
cruise control doesn't work neither do auto door locks
I read several of the posts here and looking for best advise from the pros!! I first noticed my automatic locks not quickly locking when I start off in my '03 F150 SC, and now they don't "auto lock" at all and I'm suspecting that might be related to why my cruise control has stopped as well. A month ago, my cruise started arbitrarily disengaging while on the freeway and now won't engage at all. I saw SHO89's diag steps and followed them tonight. Holding the "Off", ebrake engaged and key "ON", I get the first blink, I push "On" and get another blink, after that on the other three buttons, I get "no blinks" at all. I've never had problems with this black beauty except for the OH console resistor which you great folks helped me fix last summer and it's still working great. Hoping I can get a good plan of attack here and get my cruise control back! I've never had to replace a brake pedal switch or a master cylinder switch, but I've built more small block Ford engines than I can count, being a 62 year old shade tree from the muscle car days!
#55
on
G'dog,
1. Does the horn blow normally when the center pad in the steering wheel is pressed?
2. Press the speed control ON plus the COAST button. Does the horn blow?
3. Repeat for the ON plus the SET/RESUME buttons.
4. Report results.
The power door lock issue is separate. Either find or start a new separate thread for that problem.
4. Report results.
#56
G'dog,
4. Report results.
4. Report results.
1. yes, loud and clear
2 and 3. no, tried in key on position, tried key off, tried with engine running.
Horn does not blow with any of the ON plus combinations.
BTW, since I'm about to roll over 200k, I went ahead and replaced the switch on the MC for $20...didn't help.
Also tried your self test for the cruise again. I get 1 light when I start, one light when I press ON, but no lights when I press set, resume or coast. many thanks...
Next steps?
#58
I've built show car engines, even torn them down the night before a show; my daily driver is my black '03 F150 and my current joy in the garage is my '08 vapor/blk striped "Elleanor" Shelby GT500 with 21k miles...I've owned 5 Mustangs including an '89 GT conv., too. Thanks a ton for the assist...
#59
BTW, watched some Youtubes about changing out the clock spring last night. I don't have any problems with an air bag light, but I suppose that doesn't mean it couldn't affect the cruise controls on the steering wheel. Interesting to me is the self test doesn't report a blinking light except for the left side OFF/ON, none of the right side controls produce a blinking light during self test. Thanks again.
#60
And, simply doing nothing, my cruise worked for 3-4 days and quit coming home from work tonight, light would not come on, on dash. Would seem obvious that a fuse is not the issue, so maybe the clockspring or the CC steering wheel controls? How to test? TIA to all for any help
