Fuel Filter WTF?!
Originally Posted by iziris
so are you saying if i get no pressure in my tank my o rings or injectors need to be replaced? i do notice in my wifes car when i take the gas cap off after a good trip i get alot of pressure coming out on the other hand in my truck i never get any pressure when i open the cap.
at the shrader stem on your injector - I wasn't talking about the tank. The pressure between the pump and the shrader - The pressure in front is different then behinde the pump - fuel has a return line for excess and doesn't flow backwards - air and the gas cap means your cap isn't working lol - It' not suppose to hold air . Same principle as a cavity vent (in wall house vent)
CRAP!! It's just a filter - just get a grip , close your eye's and give it hell!! lol
Fuel Filter
If you let the truck set awhile then the lines will depressurize and you dont have to mess with the schrader valve or anything. I generally have to push the tool in 2 or 3 times before the line will disconnect. You only use the tool on one side of the filter the other end does not require the tool. Just gotta play with it a minute or two.
I didn't know that??? Guess I never heard before , so I never tried - I will next month ,
thanx
yeah buddy! no actually im not sure totally, i have to look again. but im pretty sure its long past shot. i hear it whine and hum when im holding a steady rpm down the road. sounds like its about to plug fully lol
Originally Posted by bluejay432000
That has been my experience as well. Very easy.
Originally Posted by Bartak1
Took me maybe 7 minutes last time, and I dont even have the tool to do it.
Originally Posted by The Flow-Master
How would you do this without a tool? The connections are designed to hold on until all four sides are pushed in to go over the kink in the tubing they call a lock
He's majical?
Well, actually , I was informed in this thread that you do not need the tool on one side - one side only as far as I've heard , but on mine I have the same spring clamps on both sides so idunno.
Originally Posted by Klitch
why you boys playin with the fuel filter? i got 180k on what looks like the stocker?
Holey Cow , What do you change to keep those numbers - The fuel pump
i guess its possible being a farm truck at one point the previous owner took it to ford... but judging the condition of the truck when i got it... i assume it coulda been the stock one. this thing hadnt been touched by any rednecks until i found it.
Actually it is possible , I don't want to beleive that tho seeing how I prolly changed out over 30 or so in my truck lol. I'm still glad I have, I've seen how dirty mine have gotten. I never had one go totally bad to where it would effect the way it runs tho. I guess it's possible you have the stocker on there.
hey! maybe my sub is keeping it from packing itself full? making it settle on the bottom of the filter.. hah hah hmm?
lol. i might replace it and see just how bad it is. im pretty sure its whats making the humming noise. soon as i cut the engine rpm to an idle it goes away. and it sounds like its just below my sub...
