FlyWheel Rubbing
Old Dec 5, 2006 | 06:25 AM
AdamO's Avatar
FlyWheel Rubbing
I just had some pretty extensive work done on my 02 F150 with a 4.6. Both timing chains replaced, all guides, tensioners, oil pump, all related hardware replaced. Now I have what sounds like the flywheel rubbing on the pressure plate? The mechanic doesn't believe it was anything he did cause he worked on the other end of the engine, but the noise was not there when I dropped the truck off. Any ideas?
