Starts up then dies... 4.0 Exploder
Old Dec 4, 2006 | 11:50 PM
Zaairman's Avatar
Hey guys, my buddy's 4.0 Exploder with 103K starts up and dies right away if you don't give it gas. There are NO check engine lights whatsoever. He doesn't know squat about cars either. It still dies even after it's warmed up.. any ideas? I asked him if it's ever had a tune-up and he goes, well, I thought they did it everytime they changed the oil.
Old Dec 5, 2006 | 12:28 AM
stopper's Avatar
Iac.
Old Dec 5, 2006 | 01:02 AM
Camarothatcould's Avatar
IAC YES! Had a problem on ou 4.0 Explorer at 40,000 miles. IAC replaced. then it was happening again and replaced fuel pump. Still has trouble starting once in a while
Old Dec 5, 2006 | 04:19 AM
chrism9232's Avatar
a friend of mine had a grand am. His did that he was real low on oil we filled it up then it run fine. The computer turned it off
Old Dec 5, 2006 | 08:22 AM
Quintin's Avatar
OHV or SOHC 4.0 liter?
Old Dec 5, 2006 | 08:23 AM
Zaairman's Avatar
No idea there Q, it's a Sport model, probably a 99-00. When it gets above 7* outside I'll go and look. Would the year help?
EDIT: It's a 2000.
Old Dec 5, 2006 | 09:28 AM
Quintin's Avatar
2000 could still be either. Like the other guys have said, I'd suspect an IAC sticking too, although if it's a 4.0L SOHC, the lower intake gaskets could be leaking on cold start up.
Old Dec 5, 2006 | 12:45 PM
the4by4freek's Avatar
Does it stay running if you hold the gas pedal slightly? If so then IAC. I have changed out 5 in 5 different Ford vehicles in the last 4 years.
