Ford’s short threaded spark plugs – Beware!
HI!... We were just screwing with you. Take a pill. It's like coming on here and telling everyone that the earth is round instead of flat. The sparkplug blowout issue has been very well known for about 7 years now. Just thought that you being a member here since 2001 you might of heard of it................
I had 2 shoot out on me in the course of a month. Its sucks and is a pain. The ford tech told me its cause either I used the wrong plugs or I didnt tighten them down well enough. I just rolled my eyes and walked away.
True. That's about it. Or you cross threaded.
Blown Plugs please help me
Hi I have blown three plugs out of my 2001 f250 it drives me nuts to see that I'am not the only one everyone I have read about has had the exact same thing happen. I'am in the process of going to small claims court for this problem that we are all experincing. I would greatly appreciate other peoples experiances with their plug blowouts. It would be great if anybody on this site could email me at blownplugsatyahoo.ca so I could get a copy of their repair recieps so I can have actual proof. The websites are great but in court a lot of websites are just become here say, were as recippts would be a lot more useful to make them pay for would they have put us through.
Thanks blownplugsatyahoo.ca
you will be found liable/ at fault for not properly torquing your spark plugs...
Yea, it depends on where you read or look. This chart here is from the library -
It's real goofy as far as the charts, but in the real world, -who uses a torque wrench on plugs ? I never have , not until these issues came up and that was just out of curiosity. On the tapered plugs it's always been 1/2 to 3/4 turn after seat. That will put you at 20' lbs +.
In 99, the robots supposably OVER torqued the plugs, these vehicles where called back. If the consumer failed to bring it in, shame shame. Most of those models where caught at the dealerships, before sale. Info is real sketchy on that recall, I can't find any on it now , not even on ALLData. To search ALLData, you would have to have a 99 vehicle account being the site only reflects vehicle specific info from the manufacturer . I have read about that 99 model recall in the past.
BTW- The service DVD says 12-16' lbs lol.
The heads are Aluminum, and if the plugs were torqued too tight, the threads are easily ruined, and then the plug pops. Also, if the plugs weren't tightened enough, then there aren't enough threads to hold it in place - the plug could eventually back off and blow out.
Put some anti-seize lube and then carefully tighten them all to the specified 19 ft-lbs of torque. autolight double platinum plugs which are very easy on alluminum heads!! It has been 2 years for me with no problems changed at 105,000 now has 134,000
Professional testing has proved best to -
1. Use the OEM Motorcraft plugs DRY,- No anti-seize.
2. Torque to 28' lbs.
