Gas Milage
Old Nov 22, 2006 | 11:05 PM
fishingtrout's Avatar
Gas Milage
Recently Purchased a 2002 with the 5.4 engine. I'm really surprised at the low gas milage, anywhere between 9 and 12 mpg. Haven't taken a trip to check the highway mpg. She's extended cab, 4X4 FX4, Lariat, with all the bells and whistles. Am I just hoping for too much or can some changes be made as K&N,etc?
Photo:
https://www.f150online.com/galleries....cfm?gnum=8663
Old Nov 23, 2006 | 01:46 AM
PZX_2002's Avatar
Hey fishingtrout, I also have a 2002 with the 5.4 engine but mine is a supercrew (2 wheel drive) I get 11-12 mpg in the city.
I have not changed my spark plugs nor replaced the upstream 02 sensors so you may look into that on your truck..Some people get anywhere from 13-15 on average so we are the unlucky ones I guess
Old Nov 23, 2006 | 07:57 AM
Thanks, I had planned on changing the plugs and plug wires but hadn't thought about 02 sensors. Maybe a K&N air filter would also help, and I usually add a can of SeaFoam to a tank of gas every other month to keep injectors clean. Thanks again for the ideas.
Old Nov 23, 2006 | 09:40 AM
Alibuma's Avatar
I just got 245 miles on 15 gallons of gas this week, mostly highway driving. That's a little better than 16mpg. Scab, 4x4, 5.4l, 3.73 gears, 135k miles, everything stock but magnaflow exhaust.
Old Nov 23, 2006 | 05:50 PM
worland's Avatar
That's a little low even for a 2V 5.4L. I get almost 15 MPG in my stock 5.4L SCrew in 50/50 driving. My first guess for your low MPG would be your driving habits. Keep the RPM's below 1800 when accelerating, coast to a stop, don't romp on it at lights, etc... will make a huge difference in these rather heavy trucks.
You don't need to use fuel injector cleaners. Not only are they not necessary, they'll rob you 1-3 MPG.
Old Nov 23, 2006 | 05:58 PM
OVER_KILL's Avatar
Please explain?
Old Nov 23, 2006 | 06:10 PM
I'm pretty easy on the gas pedal. I only have a 5 mile drive to work and what little driving I do around town is close. That maybe the most of my problem. As to the injector cleaner dropping the mpg, I too would like some further explanation.
My other truck was a '93 Chevy with a 350 and about 192,000 miles and I still got 15 to 17 mpg. Just thought the newer Ford would be better , but never figured in the 4X4.
Old Nov 23, 2006 | 07:30 PM
F151's Avatar
The short rides are most of it. The engine is not up to operating temp. for half the drive to work, using more fuel.
