5.4 Knocking
Old Nov 15, 2006 | 06:27 PM
HiVoltage14.4's Avatar
5.4 Knocking
I just got my 05 Lariat with the 5.4 and at idle its knocks a little bit. I didnt know if this was normal or not. Any thoughts? Thanks
Old Nov 15, 2006 | 07:38 PM
ian51279's Avatar
Mine has a slight tick, but no knocking. These new motors tend to be little noisier than the old ones. I would take it back to the dealer and let them look at it.
Old Nov 15, 2006 | 08:27 PM
dkstone05's Avatar
my has some ticking, which should only be the fuel injectors which is by no means a knock. If it is knocking I would definitely take it to the dealer.
Old Nov 15, 2006 | 08:31 PM
BABA4488's Avatar
yea mine idles rough at times too, does yours knock after driving long distances or knock after start up?
Old Nov 15, 2006 | 09:02 PM
Mine seems like it does after long trips. Its not that bad but you can hear it distintinctively.
Old Nov 16, 2006 | 08:28 AM
Faster150's Avatar
poor idle quality and piston slap from the long stroke of the 5.4 completley normal
Old Nov 16, 2006 | 09:32 AM
SAJEFFC's Avatar
Does it only do it at idle? Does it go away as soon as you speed the engine up over 1000 RPM? If so its the cam phasers. They are the "sprockets" on the end of each cam that control the variable cam timing. There is a TSB out on them and it is a warranty item. I had to have both of mine done and now the engine is dead quiet at idle. You have to really strain to hear the light injector tick but the loud tick is gone. Another way to tell is stand by either front wheelwell and you can hear it better there if its the cam phasers.
Old Nov 16, 2006 | 09:33 AM
JasonFX4's Avatar
At about how many miles does this noise making take place? Mine runs so smooth and quiet sometimes I have to look at the tach to see if its running.
Old Nov 16, 2006 | 09:50 AM
SAJEFFC's Avatar
Mine started on one side at about 6k miles, had the other side done at 12k miles. It really can do it anytime from day one. The later 05's on seem to have been corrected from the factory with the updated part. Once updated, they are a very quiet engine.
Old Nov 16, 2006 | 12:34 PM
sysman_rick's Avatar
Yup,later '05's are quiter. Mine is a July 05 build. I have to strain to hear the injectors. The cam phasers are deally quiet(19K miles on truck).
Old Nov 16, 2006 | 02:37 PM
JasonFX4's Avatar
Ok good, I thought I was going to have to get upset there for a minute
Old Nov 16, 2006 | 06:16 PM
Ok mine is a 11/04 build Where can view that TSB at?
Old Nov 17, 2006 | 09:33 PM
Jocko's Avatar
Have an 05 with a similar problem. Loud "Ticking" and intermittent knock at idle. Do you have the number on the TSB.
Old Nov 28, 2006 | 02:32 PM
derhicks's Avatar
I think they are probably talking about this one. TSB 06-4-7. I addresses about every ticking and knocking noise that there is.
Old Dec 14, 2006 | 09:45 PM
HWY4X4's Avatar
TSB's
as far as these tsb's do you just take your truck back to ford and get them to look at it? and is this warranty only coverage or any ford product? so i guess the extended service contract is a good idea? considering i bought this 05 with 39000 miles on it had a great price though
