45 flashes of the check engin light
2000 f-150 4.6 truck sputtering and check engin light comes on and flashes 45 times but does not stay on ? this happens off and on when under load any thoughts? had simmilar prob with a bad cop 3 months ago? maby another cop?? but this time the light flashes instesd of staying on? cant read the code because the lite wont stay solid????
the ford dealer told me that they cant scan it because the light did not stay on?? sounds strange. i went out to look under the hood and started it up and the light is now on steady. so ill go get it scaned. it has almost 100k on it and few months ago i replaced a cop. do these cop's tend to go out one at a time with out warning . it feels like a cop , i mean the truck acts like it did when the 1st cop went bad ? thanks
had it scaned at auto zone today. came back cyl 7 missfire same as three months ago??? i changed the plug and new cop last time (3 months ago ) is my cop bad already in a 3 month time? dont know why im missing on the same cylnder? truck is almost at 100k and 3 months ago put in all new plugs 1 new cop on #7 and had a moto-vac done . please help , do cops go bad this quick? or is this a injector prob, i tend not to think its a injector because of the recent cleaning (moto-vac)
Originally Posted by brandonhadnot
are you cop's motorcraft or and offbrand? sounds like you got another problem and its causing that cylinder to recieve the fault trace back where the cop goes from spark plug and go reverse see if what its plugged into isnt going bad.. might try some electric cleaner that way its making contact correctly.. ill do some looking and keep ya informed..
well... your suppose to use it.. irregardless of what anyone says... cause if you dont.. it will burn your wires and plug if any moisture gets in and hits it.. i use it its better to be safe then sorry.. you dont want it to stick you want it secured and away from risking of any moisture gettin in .. do you know your getting spark thru the cop.. ? theres a water spray bottle as a mist ...test you can do its an old fashion way to see if your wires are getting spark you should be getting some kind of code.. unbolt your battery cables bout bout 15-30 mins let the cpu reset itself .. go in to learn mode.. and see if it does it again
