e-fan recommendations?
Old Oct 12, 2006 | 06:49 PM
waterman308's Avatar
Got the Xcal2, AF1 and now am considering the efan mod (03 Exp 4.6). From what I can see, the two top contenders are the Troyer Fan kit and the FAL kit. Wondering about quality/reliability, ease and quality of installation materials and system and general experiences.
Thanks for your input.
Old Oct 12, 2006 | 06:56 PM
brandonhadnot's Avatar
hey where did you find these efans... im considering installing one on mine.. send a link help a brother out..
Old Oct 12, 2006 | 07:07 PM
racerf150-2's Avatar
hey i havent installed them but i have the troyer efans ( just got them in the mail yesterday. im installing sat. i did look through the box and everything is pre wired and i read the directions... VERY VERY DETAILED. it tells u which wire goes where and how to get to the where. i have heard nothing but good about the troyer fans thats y i purchased them. www.troyerperformance.com
Old Oct 12, 2006 | 07:46 PM
2001Screw4x4's Avatar
Go with the FAL. Better mounting over the Troyer kit - bolts on versus ties through radiator. Plus, with the FAL you get a shroud so the fans pull through more of the radiator. The Troyer kit does not have a shroud, and the fans only pull through the area directly in front of each fan. Yeah, lots of guys run the Troyer fans, but IMHO the FAL kit is much better.
Old Oct 12, 2006 | 08:04 PM
Faster150's Avatar
get a single 16" fan atleast 2800cfm. and a thermal switch with a relay. and hook up a mechanical on off switch to the relay so u can turn it on when uve got the ac on and ur idling not moving.
Old Oct 12, 2006 | 10:02 PM
source for fans
Brandon,
The two places I have seen are: troyer performance (a sponsor of this site) and the flexalite.com (Others on this forum have suggested Summit Racing as a good source for the flexalite fans)
Wondering about anoyone's experience with either kit - especially wondering about reliability. I have no worries about the mechanical fan keeping my engine cool. How good / how long do the electric motors work, and what to do if they die?
The "promise" of gaining noticable hp, throttle repsonse and maybe a little mpg is very tempting. The logic of electric fans makes a lot of sense.
Old Oct 12, 2006 | 10:15 PM
ws6_guyscrew's Avatar
I've heard good things from Troyer and they are very popular, so I'd say go Troyer, If I could I would
Old Oct 12, 2006 | 11:52 PM
98Navi's Avatar
Iheard good things about mikes kit (mike is Mike Troyer of Troyer performance) except that no one like the mounting kit. Some had said it caused issues year or so later with the mounting method. I personally chose the flex-a-lite kit and man, it'd be hard to beat. It mounts directly in your stock mounting position so theres nothing to run through the radiator, hell even a rook shadetree mechanic could do it. Its like $425 shipped from summit, and well worth the cash.
Old Oct 13, 2006 | 08:28 AM
well ill look in to it... appreciate the input.. right now finances arent where i want them to be.. so i just wanted to know where it found... and i like the suggestions you fellers have had to say .. but ill put that on my wish list see if my sugar mama will get it for me..
Old Oct 13, 2006 | 11:54 AM
Etech04's Avatar
flex a lite nice but no power gains
I put the fal in about 6 months ago. nice enough kit, look almost factory.
No gains in pwr or mileage. (strange because less work for the motor should = more mileage..) very noticable gain in noise.. you cant hear it in cab but with window open you get a good whirring.. no problems to date. seems reliable and no cooling problems pulling 700lbs. keep your fuse diagram handy as youll need to tap into your a/c relay and ignition on/off. I still havnt gottn around to tapping either one so my fan is controlled only by temperature.. which means after shutting truck off it, fan comes on and off several times .. like the little japanese cars.. lol. sounds a bit like star wars when it comes on so its funny. never caused any battery drainage problems either.
IMO.. without pwr or gas gains, its a waste of $400.00. (summit shipped to your door). Stock fan does the job without the noise.
Old Oct 13, 2006 | 11:55 AM
Etech04's Avatar
oops - i meant 7000lbs
Old Oct 13, 2006 | 06:41 PM
98Navi's Avatar
There has to be at least some gain (probably more than the alledged flowmaster loss; sorry, just had to jab at someone with that) You are removing a huge drag on the belt taking that fan offline. Mine come on and go off after shutdown as well 2 or 3 times, but I let it do it.
Old Oct 13, 2006 | 06:57 PM
Mark05KR's Avatar
I've had the Troyer fans on my truck for almost 2 years now. The only problem I have had is with the controllers. When setting the turn on temperature it is VERY IMPORTANT not to turn the screw past the stops, which is far too easy to do. I ruined 2 controllers by doing this. The first one, Troyer replaced for free. The second one I had to pay for.
The controllers have been working fine since I got them set, but in my opinion, they are way to easy to ruin just by turning the tiny little screw too far.
One other thing, I coated the legs of the relays on the controllers with dielectric grease. One of my relays shorted out due to water getting into the controller.
Old Oct 13, 2006 | 08:19 PM
GIJoeCam's Avatar
Search, please, and all your questions will be answered.
This question comes up at least once a week. Troyer, FAL, and LFP are all good choices. They all have their benefits and their shortcomings. Everyone picks one for a reason, and they all increase the Hp at the wheels by the same amount.
-Joe
Old Oct 14, 2006 | 10:04 PM
BLUE20004X4's Avatar
Here is my FAL setup, great item IMO. I too have heard pros/cons about all so really go with whatever one. The FAL move the most air (advertised) and I don't think mine have come on past 60% yet (3300 cfm's). The controller is pretty sweet.
