EGR Valve Replacement Help
Old Oct 10, 2006 | 10:19 AM
reese006's Avatar
Long Story Short - I am trying to replace my EGR valve and had a couple of questions. The bolts that hold the valve on are 10mm and looks like I'll need a deep socket to get the one in the back off.
Questions:
1) What about the pipe with the large fitting, what is the best way to get this off? Does that fitting actually rotate? Or is it better to undo the valve completely and rotate the valve off of the pipe?
2) If the fitting on the pipe does rotate and I need a wrench, does anyone know the size of it? Apparently in a flash of brilliants I stored most of my non-everyday tools (socket sets, large wrenches, etc...) in storage because we are building a house. It would take about a day just to get to the work bench where they are, which is of course all the way in the back of the storage building. So looks like I'll be getting to buy a few extra tools.
Long Story - Had a code of P1406 and I replaced the DPFE sensor. Truck ran fine up until the other day and my check engine light came on again and this time it is code 402 (if I remember correctly), which ever code is for a bad reading from the EGR valve. I reset the code to see if maybe it was just a one time bad reading and it tripped it again yesterday. So I was going to replace the EGR valve to see if this helps. I have read several post that suggest to clean up the throttle body but I'm not sure if I am ready to tackle that just yet. This looks pretty detailed and straight forward:
http://www.fordf150.net/howto/throttlebodyclean.php
But I may have to wait for a weekend in which there are not any good college football games on and I can be with out my truck for a weekend in case I screw something up.
Old Oct 10, 2006 | 10:24 AM
brandonhadnot's Avatar
the bolts are easy to break off becareful... i done been down that road... deep socket and a 6in extention .. the pipe fitiing you need to unbolt metric.. all nuts and bolts are metric.... not sure the size.. but be careful
Old Oct 10, 2006 | 10:30 AM
reese006's Avatar
Thanks! So how did you get the pipe fitting off of the valve? Do you remeber if that fitting rotates? Or does the valve rotate on to it?
Thanks for the heads up on the bolts breaking off. I may pick up something to help free them up.
Old Oct 10, 2006 | 10:34 AM
the fitting is like gas pipe... if you ever worked with any... same sinario the nut screws up to the egr valve i think..
Old Oct 10, 2006 | 10:38 AM
reese006's Avatar
Thanks!! That's what I thought but I did not want to be putting all my energy in to a fitting that does not rotate. I guess then it may be better to undo the pipe fitting first and then the bolts that hold the valve on.
By the time it's all said and done I may end up spending more money then it would have cost me at a shop but the wife will never know that.
Old Oct 10, 2006 | 10:42 AM
how you figure that... if you bought the parts already to do it yourself... then your not payin for labor.. if you take it to the shop get ready to spend 65 and hour for labor... cause its about 2 hour job...at ford and they dont get in no hurry for no one.......... so you do the math
Old Oct 10, 2006 | 10:45 AM
let me know how it turns out.... my *** is tired i havent been to bed yet... working nights sucks ***...
Old Oct 10, 2006 | 10:56 AM
reese006's Avatar
Only because I have to buy a socket wrench, 10mm socket, extension, wrench (maybe an entire set if I can't get a single to fit the pipe), penetrating lube for the bolts, and what ever else I decide I need while I'm in the store.
