Help! Motor stalls when I hit accelerator???
OK, so when I hit the gas from idle, my truck stumbles all over itself and sometimes even stalls. I've had a couple of dicey situations when the truck has stalled while trying to cross an intersection. Anyone know what could be causing this? So far I have replaced the plugs, wires, rotor cap, fuel filter and a bad catalytic convertor. Any help would be greatly appreciated.
Thanks,
Hunter
Thanks,
Hunter
You got it....crap.
Not easy nor cheap to replace. I've heard new pumps go for over $300.
If you have dual tanks you can try just using the other one for the time being, since they have seperate in-tank(thanks, Ford
) pumps. If you're handy and have a high tolerance for frustration and gas fumes, then DIY.
Without starting the motor and the door open, turn the key to ON but don't start the motor. You should hear an audible "whirr" from the selected tank. If it's faint(should be easily audible) or you can't hear it, it's going or gone. It must still be going if the motor runs at all, since the high pressure might be able to sustain it's prime with only minimal low pressure(in-tank) flow. The motor won't run at all if either one is bad, and almost always the in-tank one goes.
) pumps. If you're handy and have a high tolerance for frustration and gas fumes, then DIY.Without starting the motor and the door open, turn the key to ON but don't start the motor. You should hear an audible "whirr" from the selected tank. If it's faint(should be easily audible) or you can't hear it, it's going or gone. It must still be going if the motor runs at all, since the high pressure might be able to sustain it's prime with only minimal low pressure(in-tank) flow. The motor won't run at all if either one is bad, and almost always the in-tank one goes.
Ok guys...I listened for the pumps priming (dual tanks), and both sound strong. I thought that you guys were probably right, but now I don't think that the pumps are the problem. The problem occurs no matter which tank I'm using. I'm perplexed now. Oh well, I guess I'll just wait until the other shoe drops.
Thanks fellas, I knew I could count on your help.
Have a good one
Hunter
Thanks fellas, I knew I could count on your help.Have a good one
Hunter
Originally Posted by Zaairman
Sounds like it's flooding to me...
Thanks guys,
Hunter
had the same problem with my 5.0..its all the fuel pump in the rear tank.or by the frame rail...you can get a tool from oreillys for about 8 bucks and keep it forever..or your starter..thats what was wrong with mine..hope this is some help...
after i replaced my fuel pump..my starter went out..but that might just be because it was 4 years old..the fuel pump is a pain to get off..but just be patient and get the tool..i am glad i bought one
Not quite sure what tool, as there's a few tools at O'Reiley's. And then he says it could be the starter's fault???? WTF? Wha..how?Next he says his starter went out cause it's 4 years old, and to buy the tool. What is "the tool?"
