Engine Swap
Old Sep 29, 2006 | 01:50 PM
DCoates97's Avatar
Engine Swap
What does it take to swap a 97 4.6 for a 98 5.4? In a 97 f150 5 speed.
Old Sep 29, 2006 | 07:52 PM
BLUE20004X4's Avatar
Probably just time, tools and help! I can't see there bieng that much difference, but have to ask why? What's wrong with the 4.6? You can boost power just the same, seems silly to switch just because one is a bit more powerful, if the 4.6 has bit the dust than get at er. There are folks in here that have done it, didn't seem too laborous or having to switch a whole bunch of crap etc. Have fun.
Old Sep 29, 2006 | 08:09 PM
JMC's Avatar
JMC
25 Year Member
You would be better off with a 99+ 5.4. It has more power than the 98 and it will take the same amount of labour to make it fit. Wire it using your 4.6 harness. Lengthen the oil sending unit wire and extend the IAC wires. Fab up brackets and or extensions to attach the coil packs to the 5.4. Make sure you get an 8 bolt flywheel with a new pilot bearing. Pull tho old engine and fit this one in. Have a custom chip burnt to accomodate the extra cubes. You will also need a muffler shop customize the collectors. The 5.4 has a higher deck so the collectors are at a different hight and angle. Then start saving up your money for a new tranny. With the extra torque I would install a girdle on the 8.8 differential. It muight bite the dust too.
JMC
Old Sep 30, 2006 | 01:03 PM
ws6_guyscrew's Avatar
Hell just get a brand new 3v 5.4L in start off with 300 horses and get the 4spd auto transmission, or figure out a way to keep it manual if possible..
