F-150 mpg problem
Old Sep 21, 2006 | 07:41 AM
ranger ric's Avatar
F-150 mpg problem
I have a 2005 F-150 XLT 5.4 liter with a 3.73 rear end ratio and 9800 miles. I purchased it new in July 2005. It gets 18 mpg on the interstate, but only gets 8 mpg consistantly in town. I am really disappointed. Is this normal, or could I have a problem that can be fixed?
Old Sep 21, 2006 | 07:47 AM
02SCrew4x4GA's Avatar
4x4? Do you have larger after market tires? (anything over stock?). Proper tire inflation, clean air filter, etc. There are a lot of variables that can affect mpg.
Old Sep 21, 2006 | 07:49 AM
ranger ric's Avatar
Thanks for reply!
No, I have nothing added and the truck is a 2 wheel drive. Any other ideas would be appreciated.
Ranger Ric
Old Sep 21, 2006 | 07:54 AM
Ranger Ric
Well i just got rid of a Lightning, and I could always see 8mpg if i got on the gas, which was often in that particular kind of vehicle. Other then that, check your tire pressure and air filter. Other then that I cannot think of anything on an 05 2wd that would cause a MPG difference like that. Goodluck.
Old Sep 21, 2006 | 08:13 AM
GerRod's Avatar
I have an 06 5.4L 2WD Screw with an AF1 and Magnaflow catback that I run with a TP 87 performance custom tune. I drive the truck as soft as it can be driven around town and only get 13 mpg. I think it's the nature of these trucks and you won't get much more than that no matter what you do...
Old Sep 21, 2006 | 09:07 AM
That sounds about right. Although I get 14 to 15 in my 4x4 Screw and 19 on the highway. Ordering a set of pulleys later this week to help the highway situation.
Old Sep 21, 2006 | 09:24 AM
brandonhadnot's Avatar
Exclamation very confused.. not sure which way to go...
i got a 99 f-150 ext.cab 104k miles 4.6L i think it has 3.55 gears not for sure....but i have changed: plugs,wires,maf,all o2 sensors,air intake sensors, k/n air filter, got a tornado fuel safer in intake tube , changed egr valve and sensor, pretty much every sensor on the truck.. have had the cats tested to see if were clogged... which arent.. both intake manifold gaskets had a fuel lean problem at one time.. the truck used to get bout 21-24 mpg bout 6 months ago using 87 octane ...but running 91-93 octane in it now i get 13-15 if im lucky... but as time progressed the truck has lost power... just has no guts.. any solutions..? ideas i'm all ears.. where did the power go how do i get it back?
Old Sep 21, 2006 | 09:34 AM
That is a wide variation. However, if you do all stop and go in your city driving with no long stretches "at speed" and a lot of idleing at stop signs, I think that it is possible. I get 19.3 on the highway and 17.2 around town, but a lot of my town driving is on freeways and long stretches between stops.
Old Sep 21, 2006 | 09:36 AM
tex_n's Avatar
Brandon, remove the tornado.....use 87 octane. make sure tires are properly inflated and heck, you've changed everything else, what about the fuel filter?
Old Sep 21, 2006 | 09:38 AM
dude my fuel filter is good... tires are the right size 255/70R 16 have proper inflation.. my driving is mainly on interstate.. 70-80 mph speeds... not much stop and go traffic...
Old Sep 21, 2006 | 09:46 AM
RacingJake's Avatar
How are you figuring the mph's, sounds like you can't even go 200 mile on a tank of gas. Some folks here say there's a hi-tech gage in the newer truck's thats tells them their mpg's. Don't think I'd trust that, I like the old fashion way of filling the tank up and divide the miles.
Old Sep 21, 2006 | 09:50 AM
sysman_rick's Avatar
Thumbs up
A suggestion:
Reset the pcm(disconnect the battery neg terminal) wait 30 minutes.
This should reset the unit so that it can "LEARN" your driving habits.
I have a "05 KR supercrew with 5.4l and 3.73 rear end. My fuel economy has never been that bad. I drive a combination of city/highway.
Old Sep 21, 2006 | 10:01 AM
i average bout 320 miles on 22 gallons of gas when i used to get bout 380 -425 miles to take.. i do like you divide the miles by the gallons
Old Sep 21, 2006 | 10:15 AM
pic of truck
https://www.f150online.com/galleries....cfm?gnum=8345 heres what it looks like.. if you all are interested in checkin out my truck there are a couple others on my gallery
Old Sep 21, 2006 | 10:48 AM
xopis's Avatar
That comes out to be ~14.5 mpg...
