Oh dear!
I have 4 error codes on my 2005 F-150 XLT 5.4 Screw!
P2104
P2106
P2111
P2135
I have checked on all OBDII code forums I can find and the highest codes go to is P1999!!!!
Do I need to drive my truck into the closest river and wave her goodbye
Anyone help?
P2104
P2106
P2111
P2135
Anyone help?
Hi.
Hmmm ...
ETC codes ?
Try plugging those codes into here:
http://www.iequus.com/support/obd2_definitions.php
...(The Equus link in the thread below does not work)
https://www.f150online.com/forums/sh...ighlight=P2104
These are relatively new since the advent of drive-by-wire / ETC, so some databases don't contain them (yet).
In any case, I believe your only recourse is a dealer visit. Should be a warranty issue - there have been reported cases of faulty ETC TB's. Replacement & /or reflash ... Quintin, any recent input?
Hope this helps.
Cheers
Bubba
Hmmm ...
ETC codes ?
Hope this helps.
Cheers
Bubba
Cant go to a dealer as i'm in the UK so have no warranty etc
Anyone explain fully what needs to be done/what is wrong?
(What is a ETC code?)
ETC: a.k.a electronic throttle control, a.k.a "drive-by-wire", a.k.a. little pile of silicon calling the real shots on your right foot's input
Good luck.
Cheers
Bubba
P2104 Throttle Actuator Control System - Forced Idle
P2106 Throttle Actuator Control System - Forced Limited Power
P2111 Throttle Actuator Control System - Stuck Open
P2135 Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation
JMC
JMC
JMC gotem right.
Listen up,,,,, many of you donnot have the corrrect or complete code list and often get mislead.
Go to the SCT Superchip site and print out the Ford specific list.
Makes a big difference.
You will see things you never knew existed.
Originally Posted by Quintin
Those are all electronic throttle control codes, and most likely can be fixed with a new TPS sensor and reprogramming the PCM to the latest available calibration.
Everything is stock except for a cat back Borla stainless exhaust (22" wheels but not fitted yet)
I have asked ford UK for help but got nothing but negative rubbish spat back at me!
Done 20,000 miles and serviced 3 times with genuine motorcraft parts apart from the last service I used a Fram oil filter that caused knocking replaced 2 weeks later with a Motorcraft one
Originally Posted by bluejay432000
Quintin, just curious, since he has a dealer problem and difficulty getting a reprogram. Would he be able to replace the TPS and use a programmer such as the Edge or Xcal2 for the reprogram?
So I need to get have the PCM sorted?
Will this sort all the problems out?
Stab in the dark but can the PCM be removed from the truck and sent off to be sorted?
Good luck
