rough idle
rough idle
my '93 4.9L started idling rough lately. the SES light has stayed off ever since i replaced the vaccum reserve can, and it also ran noticably smoother, but it still miss fires quite often and idles rough. however one time i accidentaly added alot more of a fuel additive than i was suposed to when i put some gas in it and it ran perfectly, up until i put new gas in it. so im stumped as to why it's running the way it is and not throwing a code. im assuming this is'nt really helping my gas mileage. i just replaced the spark plugs, and the wires only have 33K on them. any ideas?
thanx.
thanx.
did you check that you put the right spark plug wires on the right spark plugs
you could of switch two or have to backwards so just check the fireing order and if that is not it then you could check the timing.that could be it
Originally Posted by PKRWUD
Sounds like your injectors are dirty. Does the problem go away when you floor it? Have you experienced a slight stumble while cruising around 35 mph under very light throttle?
ok i cleaned the IAC and now it idles a little smoother but it still startles at like 23-24mph in second and at the same rpms in 1st (didnt try 3rd) iv'e got 2.73 gears in the rear and like i said no tach, but it sound like it's doing it just above 2k rpm
Still sounds like dirty injectors. Try this: Buy a couple large bottles of injector cleaner, and when one of your gas tanks becomes almost empty, go to the gas station and put both bottles in the nearly empty tank, and add about 3 or 4 gallons of gas. Drive around for about 30 minutes, and then park it for the night. The next day, go for a test drive, and see if things have improved.
If they have, but not to your satisfaction, you might consider having the injectors professionally cleaned, or replace them.
Post your results.
Post your results.
Post your results.
Post your results.
