rough idle
Old Aug 19, 2006 | 09:02 PM
calisonic's Avatar
ok i tried the fuel injector cleaner and its still running the same. i guess ill have to get them cleaned eventually.
Old Aug 19, 2006 | 09:08 PM
89carlson's Avatar
Try changing the fuel filter.
Old Aug 19, 2006 | 09:12 PM
PKRWUD's Avatar
On the contrary, if you noticed no improvement with the injector cleaner, that means it's not injector related. By testing it yourself with the injector cleaner first, you saved yourself quite a bit of money.
Try disconnecting and plugging the vacuum hose that goes to your fuel pressure regulator. This will bump up the fuel pressure slightly, so if the problem goes away, we know it is a fuel delivery problem, and can go from there.
Old Aug 22, 2006 | 10:40 AM
calisonic's Avatar
Try disconnecting and plugging the vacuum hose that goes to your fuel pressure regulator. This will bump up the fuel pressure slightly, so if the problem goes away, we know it is a fuel delivery problem, and can go from there.[/QUOTE]
ok tried that and it ran perfect, so what could it be?
btw thanx.
Old Aug 22, 2006 | 01:17 PM
PKRWUD's Avatar
btw thanx.
You need to check and see what your fuel pressure is at idle, and with the key on, engine off.
Old Aug 22, 2006 | 02:04 PM
calisonic's Avatar
could you possibly tell me where the schrader valve is?
Old Aug 22, 2006 | 02:22 PM
PKRWUD's Avatar
Certainly. It's just out of sight, at the back of the fuel rail, close to the firewall. Just reach back down behind the intake, to the passenger side of the valve cover.
Old Aug 22, 2006 | 02:36 PM
calisonic's Avatar
ok found it and... broke it. i was tightening the fitting on the pressure gauge and the outer thread of the valve broke of inside the female connector on the gauge. but no gas came out, i kept putting it in run while i was tightening it to check. but now that just the needle's there, i can push the needle in and gas comes out, just no way to measure it's pressure.
Old Aug 23, 2006 | 08:27 AM
PKRWUD's Avatar
That's not good. Your problem is in your fuel delivery. It could be several things, but you need to be able to check the fuel pressure to diagnose it. You could always leave your fuel pressure regulator vacuum hose disconnected and plugged, but that's not properly fixing it.
Old Aug 23, 2006 | 08:54 AM
calisonic's Avatar
ya and i dont think that would be the [[I]best[I] thing for my gas mileage.
Old Aug 26, 2006 | 09:27 AM
calisonic's Avatar
so based on what we do know, what do think the problem could most likely be?
