ford big blocks
Old Jun 26, 2006 | 11:52 PM
  #31
Bluegrass's Avatar
I gota tell that I owned a 76 F250 HD Super Cab with a 390 4 barrel from the factory.
Wished I had that truck again today. It would out pull any of FORDs v8s of today under any of the same load conditions without being modified in any way and get the same or better fuel mileage and no overdrive.
When I got it used I thought it was a 427 the way it ran on the way home till I varified it was a 390. Man what a truck!
16.5 rims, floating rear axle, big-big brakes etc. The suspension made it feel like a little 1/2 ton.
Before that I had a 76 150 SC new with a 360 that could not pull a **** ant off a hill.
Old Jun 27, 2006 | 12:10 AM
  #32
Zaairman's Avatar
Originally Posted by mark150
Transmission with the 460?
Make it easy and go with a C6.
Old Jun 27, 2006 | 08:06 AM
  #33
expy03's Avatar
X2. Cheap,easy to build, and strong. Although I wish I had an overdrive.
Old Oct 10, 2006 | 09:45 AM
  #34
Virilha's Avatar
Originally Posted by Marc Carpenter
390-427-428 FE would be a fine choice.
I built many and they make nice power. The torque is unbelieveable.
Nice cam, intake, maybe a set of aluminum heads, headers, and a good old Holley, or Edelbrock 650 or 700 and you have a real beast on your hands.
I think it is a good idea. Let us know if you pursue it...
Marc is that to hard to install a ford 6.8L v-10 in a 2005 F-150 with a 5.4L ?
Thanks.
Old Oct 10, 2006 | 10:47 AM
  #35
Zaairman's Avatar
More like damn near impossible...the wiring would be a paaaaaain to figure out.
Old Oct 10, 2006 | 10:49 AM
  #36
redneck101's Avatar
I agree.I've had both and the 460 is twice the motor that the 5.4 is.
Old Oct 10, 2006 | 01:41 PM
  #37
BLUE20004X4's Avatar
Originally Posted by KingT
I wanna do a big block engine swap to my 2002 f150 and im wondering wat size engine i should get. I was thinking the ford big block 460.
I thaught about throwing this into the truck for fun, seeing how my car project was at a stand still with body work, but then things picked up so I decided to keep the 5.4 and do one day a real modern hot rod with it. I still think it's an easy way to get 650 hp's!!!!, Let us know how you make out, it would be wild for sure and you'd get my
Old Oct 10, 2006 | 09:43 PM
  #38
Powerdude's Avatar
Just put the Triton V10 in there. Bolt compatible with the transmission, similar engine management system. Should be a piece of cake.
All you have to do is lengthen the front of the truck by a few inches.
Should be nothing to it. Either that or move the radiator to the truck bed.
Old Oct 10, 2006 | 10:17 PM
  #39
Zaairman's Avatar
Suuure. Nothing to it. Besides the fact that the wiring will be damn near impossible, especially if you want to run your stock gagues and such.
Old Oct 11, 2006 | 10:19 AM
  #40
Virilha's Avatar
There is no need to lengthen the front of the truck by a few inches.
Why not install an electric fan ? A lot easier.
Old Oct 11, 2006 | 11:29 AM
  #41
This idea of a V-10 is cool, especially a new 3 valve with a blower. It can make sick amounts of power and is unique. Also, the fitment wouldn't be bad at all, but as mentioned, e-fans would be the only way to do it.
Old Oct 11, 2006 | 12:03 PM
  #42
BROTHERDAVE's Avatar
25 Year Member
385 series big block ford in a newer body style
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Oct 11, 2006 | 12:07 PM
  #43
Virilha's Avatar
Install e-fans is easy cake, won't be a problem.
Does anyone know how much HP and TRQ a 6.8 3V is rated.
Are they still being used on the 2006 f-250s ?
Old Oct 11, 2006 | 12:16 PM
  #44
Virilha's Avatar
5.4L 3V Triton V-8
6.8L 3V Triton V-10
Engine Type
V-8, iron block, aluminum heads
V-10, iron block, aluminum heads
Bore/Stroke
3.55 x 4.16 in
3.55 x 4.16 in
Displacement
330 cu in, 5400 cc
415 cu in, 6802 cc
Compression Ratio
9.8:1
9.2:1
Fuel Injection
Sequential multi-port electronic
Valvetrain
SOHC, 3 valves per cylinder, variable cam timing
Power
300 hp @ 5,000 rpm
362 hp @ 4,750 rpm
Torque 365 lb-ft @ 3,750 rpm
457 lb-ft @ 3,250 rpm
Oil Capacity
7 qt
7 qt
Coolant Capacity
26.4 qt
27.5 qt
Transmission Type
6-speed manual overdrive (all)
5-speed TorqShift automatic overdrive (all)
