MAF Sensor cleaning = no more ping!!
My truck was really pinging going up hills, or at heavy throttle.
I knew it would be a good idea to try cleaning the Mass Air Flow sensor, but just never got around to it. I was also afraid I'd damage the small wires getting the unit out.
http://www.fordf150.net/howto/clean-...low-sensor.php
I saw these directions and bought some electrical parts cleaner.
When I opened up the air filter to start the job, I could see the sensor wires right there. I decided, why not just spray them without removing the sensor??
I hosed 'em down pretty good, and was AMAZED at the results!!! The pinging is GONE!!! I can't believe it was that simple.
If anyone is having the same problem, give it a try. I hope this helps someone else out. This is a great forum. Thanks guys (& girls). -Jim
MAF in a '92?
I'll bet cleaning the MAF is not something most dealer/paid mechanics will do for you as a matter of course, unless there's something to suggest it needs it...and I imagine replacement is what most counsel. Good to see it worked for someone.
Now my question is: Is there A MAF in a '92 with the 5L engine (2wd reg cab) - there's no mention in the Haynes manual which in itself is almost fraudulent in purporting to represent models up to '96, it's got a few token updates, and almost no relevant photographs for the later EFI models...
I wonder if there's a crossover with the later manuals, as in, is there a version for the later models that goes back further? Might be more useful to me...otherwise I might have to consider buying a Ford workshop manual.
Lastly, what do you define as 'pinging' going uphill? Mine 'misses' or hestitates, but I don't hear the 'pinging' I'm told you get when you have an octane issue, etc...My engine has a couple of other issues I need to resolve before going too much further with troubleshooting (cracked manifolds but the cracks close as it warms up) but any shortcuts like this would be cool.
Originally Posted by adrianspeeder
94 was the first year for MAF on the 302. The 300 and 351 got it in either 95 or 96.
Change your plugs, wires, cap and rotar
Adrianspeeder
Adrianspeeder
