Body removal for engine change
Old May 30, 2006 | 01:00 AM
darryln's Avatar
Is is better to remove the body to do an engine swap in a 97 f150?
I heard that this was a way to make it easier, is this true or false?
Thank you for your help.
Old May 30, 2006 | 05:13 AM
matcount63's Avatar
Thumbs up dont hafta
i just drop a motor in my 97 150 didnt drop the front end
Old May 30, 2006 | 08:23 AM
Faster150's Avatar
no... pull the intake manifold off and the motor comes out easier...
Old May 30, 2006 | 02:02 PM
defective's Avatar
Given an opportunity to remove the body, i'd do that after having done a 5.4 swap in my '99 4x4 through the hood. It's do-able and not that bad getting it out, it's just getting everything off the motor that's easier with the body off. Thats how they do it at the shop.
Old May 30, 2006 | 04:18 PM
Zaairman's Avatar
If you have the tools and equipment to remove the body, then go for it. If not, you can still do it with the body on.
Old May 30, 2006 | 07:14 PM
Quintin's Avatar
In a pickup, pulling the engine from the top isn't too bad. The trickiest ones are probably 5.4 liters with external oil coolers, since the oil cooler and it's hoses tend to get hung up on the driver's side motor mount bracket. If I was doing any major in-vehicle repairs like heads or head gaskets, I'd lift the body. My back bothers me too much to spend all day leaned over the fender into the engine compartment.
