Engine Swaps
Old May 23, 2006 | 07:48 PM
jre86's Avatar
Engine Swaps
I have seen a lot of people doing engine swaps in their F-150s.
What is the maximum weight for an engine in the 97-03 frames?
How much does the V-10 weigh compared to the 5.4L?
Are there any diesel conversions for the F-150 being done?
Any information you have about different engines that would fit in the F-150's would be great!
Old May 23, 2006 | 10:16 PM
The Package's Avatar
Unless you have alot of time on your hands,or money flowing from your pockets go buy the truck you really want and dont worry about it interest rates will never be this low again. Just my opinion . I was thinking about the same thing and realized i would not be happy in the long run if it didnt turn out just right.
Old May 23, 2006 | 11:26 PM
Johngs's Avatar
The main thing is that the V10 is a big engine, and its a tight squeeze in the engine compartment (not that it cant be done). Ive seen a few threads in here about people comtemplating it but I dont think anybody has actually done it yet.
As for the front end weight, that problem is easily solved...just swap in some 7700# payload torsion bars from the F250LD/7700# F150 package and you should be good to go.
For diesel conversions, again I havent seen any on here, but if you are determined to do it there is nothing you cant do. There are diesel engines out there that will fit in our trucks, you just have to do some fabrication to make it all work.
Old May 25, 2006 | 12:09 AM
95XLTF150's Avatar
Yeah i would love to swap in a V10 into my 95 F150. But the money factor of this would be major. So i am thinking i am going to do a 302 built from the ground up or a 351. but if i can get a V10 for cheap and swap it in hell yeah i will
Old May 25, 2006 | 12:29 AM
95XLTF150's Avatar
Take that back i just looked up how much for a V10 found them for about 1500-1700. Then just to get a new bellhousing so i can mount up a c4 or c6 then i shall be set.
Old May 25, 2006 | 07:00 AM
s1037s's Avatar
you can get a complete van on ebay right now for $895 with a v10 in it
Old May 25, 2006 | 07:01 AM
s1037s's Avatar
I'm still waiting for mike to call back to see if he can bypass the PATS to make it work(v10 swap)in my truck, Thats the last puzzle piece for me
Old May 25, 2006 | 09:19 AM
mark150's Avatar
He can definitely disable PATS. My truck is running right now with his programming.
Old May 25, 2006 | 11:16 AM
Johngs's Avatar
Yeah dont worry about the PATS, mike can take care of that for you.
Old May 25, 2006 | 03:56 PM
s1037s's Avatar
finally an answer! Time to get the discover card out
Old May 25, 2006 | 07:52 PM
jre86's Avatar
How much does the V-10 weigh?
I think the 5.4L is around 650 pounds.
Old May 26, 2006 | 02:26 PM
sean_somer's Avatar
ive heard of people puttin diesals in their 150s, but i think it would be a stupid idea to put somethin like that in a lil truck, & all the things u would have to do, fuel system blah blah blah
Old May 27, 2006 | 03:50 PM
s1037s's Avatar
two sites i found said the v10 weighs 700 dry
Old May 30, 2006 | 09:51 PM
jre86's Avatar
Thanks for the info s1037s. I can't afford a new engine right now let alone a new truck. Right now I am just going to keep my 2000 running and look at my options when money isn't as tight.
Could the F-150 frame with 7700# torsion bars handle an engine that weighs around 1000 pounds?
Old May 30, 2006 | 10:50 PM
s1037s's Avatar
i hear ya.
Brakes become a major concern with an engine that big
