Washed engine - Won't Start
Old May 7, 2006 | 01:25 PM
kretinus's Avatar
Oops never mind.
problem solved and a clean engine to boot
Old May 7, 2006 | 02:35 PM
jbrew's Avatar
Originally Posted by kretinus
Oops never mind.
Holy H*** R U NUT'S?? You killed it!!! LOL , just kidding, it just happends alot, but no-one usually get's away with it...How did U??
Or did you ? lol
Old May 7, 2006 | 04:35 PM
kretinus's Avatar
Or did you ? lol
Heh, I actually wash my engine about every few months, more if I go playing. Never had a problem until today. Damn thing cranked but wouldn't fire at all, ran through all the basics, distributor fuses etc, turned out to be a bad ignition wire, unrelated to the cleaning I suspect.
Old May 7, 2006 | 04:45 PM
lees99f150's Avatar
I spray everything down with Malco Red Thunder (1:2) let it set a few and then wash everything down with a 1300 PSI washer using a 30deg tip, never had any problems with it.
I guess you cant state this anymore now.
Old May 7, 2006 | 05:12 PM
kretinus's Avatar
Sure I can, the ignition wire was already shot before I washed the engine, it was just a coincidence that it finally failed after I washed the engine, it didn't even get wet.
