automatic tran fuild would do the same thing as sea foam
Old Apr 25, 2006 | 06:51 AM
matcount63's Avatar
put tran oil in through throttle bottle and keep the motor running you need not much to clean it out a old timer taught me this and it does work good
Old Apr 25, 2006 | 09:05 AM
JMC's Avatar
JMC
25 Year Member
I have used tranny fluid or water in the past.
JMC
Old Apr 25, 2006 | 05:06 PM
lees99f150's Avatar
used to do it all the time on my old bronco.
Old Apr 25, 2006 | 09:55 PM
Labnerd's Avatar
Seafoam= 80% prox 20 viscosity non-detergent oil, 20% prox alcohol
Mercon= a 20 viscosity Gp III dino oil with friction modifiers and detergents
I think it foolish to put either in a newer, modern engine. If you guys are concerned about carbon build up, use what the guys recommend that designed, built, and tested the engine- Techron. It also doesn't smoke, screw up the air or the O2 sensors or clog the cat, etc. It safely cleans the entire fuel system, the injectors, the intake, the valves, the plugs, the pistons, etc and doesn't destroy everything down wind of the exhaust valves. Your money and your repair bills.
