5.4 Valve clatter! HELP!
Old Apr 7, 2006 | 01:46 PM
Faster150's Avatar
Originally Posted by SAU
Drain all of the oil, and drive the truck for about a week to see if the clattering get's worse or better.
Seriously though, my old truck did the same thing and it ran fine for over 100k miles.
drive it for a week without any oil are u nuts?
Old Apr 7, 2006 | 01:47 PM
Pyledriver's Avatar
Well, I AM glad to hear that this problem isn't just with my truck..and certainly happy to know that it won't affect longevity! On the other hand, that noise bothers me so much that I'm considering spending the money to have it fixed! Although...if the truck has no actual lifters...what would the mechanic replace to solve the problem? Not only that, if he replaces the factory parts with more factory parts, will this problem come up again theoretically? His suggestion to me was to drive it till it needs a new motor and then it'll all be fixed in one 'fell swoop'! I'm not sure I like that option either though...I get bored having one vehicle too long!
Old Apr 7, 2006 | 04:44 PM
truck man's Avatar
Just got my truck back from the shop it was doing the same thing guy down there say it's an exaust leak
Old Apr 7, 2006 | 05:33 PM
Faster150's Avatar
yeh if its problems with the heads then yeh drive it till u break something... its probably jusy nothing. do u have an IM program like AIM yahoo or MSN i could shoot u my number and call ya uup see what this noise is
Old Jun 12, 2006 | 11:53 PM
clintc's Avatar
Same problem here
I think my truck is doing the exact same thing. You mentioned if you pull into the convenience store, hop back in your truck and crank it up, you get the noise. What happens when you cold start it in the morning? Mine will not make the noise on a cold start like in the morning. It always happens when the motor has been warmed up and then shut off. The noise goes away in about 30 to 45 seconds. I have searched the forums and can not find the solution. There are alot of ideas out there, but nobody seems to be able to say I had that problem and this is what I did to fix it. If you find the solution, let me know. Even though I dont think there is a major problem, it sure is annoying. By the way, I have 198,000 miles but my engine is clean. I use Mobil 5W-30 synthetic.
Old Jun 13, 2006 | 02:43 AM
Faster150's Avatar
drive it for a week without oil??
