f150 4x4 will not run under load
Old 03-26-2006, 05:57 PM
temp1's Avatar
Originally Posted by lynns4x4
It Happened All The Sudden My Truck Just Would Not Move While In Gear Runs Rough. A Neighbor Sad He Had A Ford An The Fuel Pressure Sensor Went Out . I Went A Bought One Only To No Avail, Also Put In A New Fuel Filter . Anybody Got An Idea.
If its a COP and you wait long enough then you may get a check engine light.
Old 03-26-2006, 10:56 PM
JASON'S98S/C4X4's Avatar
I had the same problem and same symptoms, finally I had to have towed to my mechanic. He replaced the computer in it and fixed the problem for a couple of weeks then it did the same thing again. He replaced the computer a second time and the MAF sensor. He replaced the MAF because he said it was starving for air because of the supercharger. A year and a half later no problems except for the IAC Gumming up on me from the carbon a simple cleaning fixed that problem. 86,000 miles still running strong!
Old 03-28-2006, 09:46 AM
lynns4x4's Avatar
Thumbs up thank you
thank you
Old 03-28-2006, 04:12 PM
Source's Avatar
So it's fixed?
Quick Reply: f150 4x4 will not run under load
