Question about piston rings
Old Mar 18, 2006 | 03:53 PM
Damestic89's Avatar
I was just watching trucks on spike tv, and Jessie was talking about piston rings. He said that if you have a gasoline engine, to replace the ring at 185K. Well I'm at 171K, and wondering when you guys replace them at, considering each car/truck runs a different compression rate, and what the cost would be. Thanks.
Old Mar 18, 2006 | 04:44 PM
beckerjs's Avatar
if you need rings then you need bearings and timing chain, time for an overhaul. Lots of work but fun if you like that stuff. With having the heads done, block boiled as long as it doesn't need a bore job, new cam and lifters, gaskets and bearing set about $1200 if you find a good parts house
Old Mar 18, 2006 | 04:52 PM
98Lariet4x4's Avatar
Yeah, I have 215,000 on my truck, and still have between 115-120 lbs in each cylinder. Rings are not a typical maintenance part, they're replaced when they go bad. If you're not burning oil like crazy or smoking or feel like you're driving a 4 cylinder, you're ok....
Old Mar 18, 2006 | 05:33 PM
Bartak1's Avatar
Like 98Lariat said, unless they go bad, you dont need to replace them like a regular maintenance thing.
Unless your burning oil/seeing blue smoke, have bad compression on a cylinder, (due to the rings, could be other stuff) or are already tearing into the whole engine, there is no point to replace them.
Old Mar 18, 2006 | 05:54 PM
Damestic89's Avatar
Thanks guys, with that said, I'm just going to leave it then if there is no need. I need all the money I can to hopefully to fix the rear end.
Old Mar 18, 2006 | 10:31 PM
max mitchell's Avatar
I always replace my rings at EXACTLY 185,000 miles, but it's because Courtney told me so!
http://www.spiketv.com/#shows/xtreme...x4FlipbookOpen
Old Mar 19, 2006 | 09:06 AM
Quintin's Avatar
Replace 'em along with the rest of the engine when it blows up. Otherwise, keep on rollin'.
Old Mar 19, 2006 | 09:30 AM
Faster150's Avatar
ROFL lol amen to that!! didnt he sa Tornados and TBS's help fuel milage and HP to
