need help with codes
Old Mar 14, 2006 | 01:07 AM
josh_4450's Avatar
hey all im new here. i have a 97 f150 with a 5.4.my check engine came on after instaling a cold air intake and throttlebody spacer. my budy at pepboys scasnned it and said the code was 1132. he didnt know what it ment. so if anyone has any info i realy appreciate it. thanks josh
Old Mar 14, 2006 | 07:39 AM
temp1's Avatar
You can find an 1132 here ...
http://www.ford-trucks.com/article/i...tic_Codes.html
And some more here ...
http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
Old Mar 14, 2006 | 07:43 AM
projectSHO89's Avatar
P1132 is likely either a faulty O2 sensor (upstream - passenger side) or perhaps a leaky fuel injector.
Additionally, since you've been screwing with the intake tract, you could have the MAF incorrectly reporting the intake air charge and the computer is over-compensating.
Check your oil for a gasoline smell. If so, pursue the injector angle (and change the oil).
Otherwise, restore the system to stock and see if the problem is corrected.
Steve
Old Mar 14, 2006 | 08:14 AM
flavio marco's Avatar
Wink
You can also check for code translation here:
http://www.svtlightnings.com/scantoo...tc%20codes.htm
Old Mar 14, 2006 | 06:44 PM
jwaters's Avatar
josh
i just ran your truck year model and engine size thru my scanner software and it says the p1132 code is. ( insuff. switching 02 bank 1 sensor 1 sensor/rich ) my 96 f150 has 3 o2 sensors on it i think your is the same.
jim
