loss of cylinder compression 4.2 6 cylinder
Old Mar 13, 2006 | 09:11 PM
awelch4709's Avatar
what can cause this type of problem ?
Old Mar 13, 2006 | 09:15 PM
bcshepard's Avatar
I dont know the 4.2's very well but if memory serves me right dont their seals go bad at that section of the block? If so check for oil leaks and see if you've got a bad seal.
Old Mar 13, 2006 | 09:22 PM
Camarothatcould's Avatar
Possible blown head gasket
Old Mar 13, 2006 | 09:33 PM
awelch4709's Avatar
dealer said it was the spring but it's not .... now maybe the rod is holding the valve open but not sure
Old Mar 13, 2006 | 09:47 PM
s1037s's Avatar
how many cylinders are low, which ones, more info please
Old Mar 13, 2006 | 09:51 PM
awelch4709's Avatar
just cylinder 2
Old Mar 13, 2006 | 11:08 PM
awelch4709's Avatar
started as a misfire reading then the dealer tested it and said it was related to compression
