Fuel Pump Question 98 Expedition
I have a 98 Expedition. I went out to start it this afternoon and it would start and die. It acts like it isn't pumping gas and I don't hear the fuel pump. Is there a braker switch somewhere for the fuel Pump? Thanks Riley
or you could just open the throttle slightly, if it starts clean/replace the IAC. If it doesn't start put a fuel pressure guage on it to check for enough fuel pressure. Ten pounds low and they will not start, there is no way to tell if there is enough without a gauge onless there is none. There is an enetia(sp) switch but not likely in your case, but easy to check
Well I found out what the problem with my Expedition was. I had a key made that I could put in my billfold that didn't have a chip in it. I thought for sure I was going to have the truck towed in to get worked on then I started to think about it and I tried my normal key and it started right up no problem. The chip in the key must control the fuel pump. Thanks Riley
