quintin i need help!
Old Feb 11, 2006 | 05:29 PM
fordmuscle385's Avatar
Exclamation quintin i need help!
i have no power steering now!! what could cause this problem,
Old Feb 11, 2006 | 05:55 PM
Quintin's Avatar
On the new pump, under the high pressure fitting, did any valves or anything fall out? If the valve under the fitting is missing or installed backwards, you won't get any power assist.
Old Feb 11, 2006 | 05:56 PM
98Lariet4x4's Avatar
Assuming this is on your F-150, it cannot be the belt, as it is serpentine. Eliminate one possibility. Have you checked fluid in case there's a leak somwhere? Are all electrical connections tight? The pump may have went out if all the easy checks work out....
Old Feb 11, 2006 | 06:01 PM
i was talking to someone here and they asked me the same thing about anything falling out.......i dont recall. no leaks. i loosend the pressure line and nothing was coming out.
Old Feb 11, 2006 | 06:02 PM
lemme go out there and look around........what am i looking for, i never saw anything.
Old Feb 11, 2006 | 09:08 PM
im just gonna geta refund and exchange, tell em its defective they wont know the difference.
Old Feb 11, 2006 | 09:28 PM
Quintin's Avatar
There's a very real possibility that you got a bum pump...who'd you get it from?
Old Feb 11, 2006 | 09:34 PM
O, O, O, Oreillys! They told me they'd have a new one in monday, luckily I live less than a mile from work.
Old Feb 11, 2006 | 09:55 PM
Quintin's Avatar
Ack...I know they're expensive (relatively), but I've always had good results from Motorcraft remans.
Old Feb 11, 2006 | 10:09 PM
Oreillys wants like $56 w/ core exchange, whenever i think about anything at a dealership my butthole starts to hurt, i nver thought about a motorcraft reman tho. I'd imagine it would be better, since it is Ford and all
Old Feb 13, 2006 | 09:35 PM
I've put TWO reman POS pumps on my truck and still...absoloutly no power assist. Would the remans not come with the valve i keep hearing about. I've scoured the carport looking for soemthing that resemble anything that might be it but cant findd anything....how small, what does it look like where does it go?
Old Feb 14, 2006 | 07:09 PM
apparently, like you said Quintin, there was a valve and im gonna have to order it from Ford. for a whole $77 bucks
Old Feb 14, 2006 | 07:14 PM
Quintin's Avatar
The valve is about the size of a lifter in a 302, and goes in behind the 18mm fitting on the power steering pump. At this rate though, I'd give up on those O'Reilly pumps, bite the bullet and buy a Ford pump. You've gone through enough headaches.
Old Feb 14, 2006 | 09:04 PM
the size of a lifter?? damn i couldnt miss that. I talked to someone today that had once gone through 4 pumps before one actually worked. hell the Ford place said the new pumps dont even come with the valve. If its the size of a lifter theres no way it fell out w/o me knowin'. does it just fit loosley in there?
Old Feb 14, 2006 | 09:07 PM
Quintin's Avatar
Well, I might have exaggerated the size of it, but it's pretty noticable nonetheless. It shouldn't fall out of the pump freely, but stranger things have happened. Every Ford pump I've installed has had it. You should be able to make it fall out by turning the pump with the high pressure fitting facing down and shaking it a bit. Got a case of CRS right now, but I also think there's a spring behind it.
