help...
Old Jan 22, 2006 | 02:55 PM
princezmonika's Avatar
Exclamation help...
ok...my engine turns over but does not start....and when it DOES start...once i let go of the gas pedal, it turns off....does anyone have any ideas on what i can do or what i need to change out??
*monika* :o
Old Jan 22, 2006 | 04:37 PM
hcmq's Avatar
most likely your IAC
do a search on it.
very very common and happens without warning and does exactly what you are describing.
good luck-
Old Jan 22, 2006 | 07:40 PM
davidshick2's Avatar
Thumbs up
I would agree with hcmq the Idle Air Control Valve(IAC) is most likely the problem they are about $100.00 at advance auto. Seen this problem before put new one in solved everything. Hope this helps
Old Jan 23, 2006 | 12:40 AM
what about the fuel filter??....my dad never had it changed...it is a 2001
Old Jan 23, 2006 | 02:25 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
TRy starting the truck and hold the gas pedal this time just a bit down and see if remains running . If it does then its the IAC. The fuel filter maybe bit not likely. I think its the IAC you can try tapping on it (IAC)sometimes they stick
Old Jan 23, 2006 | 02:43 AM
racerf150man's Avatar
take off ur iac and clean it with seafoam deep creep spray.. did the trick on mine... also i would change the filter its about 15 for the filter and 6 for the special took needed... i would also do a search and clean the maf too those get dirty..
