How can I bump up the gas mpg??
Originally Posted by McNab
I have a 2001 Supercrew with a 5.4l and I just got a little over 23 MPG on a long stretch of Highway (about 230 miles) going 75 MPH.
But if you get 23 mpg going 75 mph, then you could potentially get 25-26mpg if you slowed down to about 55 mph.
Others have covered this. In summary:
In general, maintain your truck and don’t forget the often overlooked items like power steering fluid, fuel filters, and transmission service. As fluids age, they oxidize and usually increase viscosity producing increased hydraulic drag.
- Check tire pressure
- Check and replace air filter
- Use lowest viscosity oil specified for your truck
- Service transmission every 30k miles
- Accelerate slowly and smoothly
- Use 87 octane (unless you are chipped)
- Don't idle for more than 2 minutes
- Slow down
- Change fuel filter per mnfr's recommendation
- Replace power steering fluid
- Put truck into neutral at long stops
Best thing i've found is to park it and drive my wife's taurus.
