2002 Supercrew using oil-why?
Old Jan 11, 2006 | 04:15 PM
keborg's Avatar
Angry 2002 Supercrew using oil-why?
I have a 2002 Supercrew 4x4 with 50,000 miles on it. I have noticed in the past two oil changes that I'm a quart low at around 2,000 miles. Previously, the engine has not used a drop of oil between oil changes (I change every 2,500 miles).
I typically have used the Motorcraft 5W-20 synthetic blend. But I haven't always been able to get it. So recently have been using Quaker State 5W-20 (non-synthetic blend).
Question #1: What could be the reason for the sudden loss of oil?
Question #2: Is it related to the switch in brand/type of oil?
Question #3: Is there a way to remedy the situation?
There is no obvious blue smoke at start-up or when running. Nor is there any evidence of leaking on the garage floor.
Any suggestions would be welcome. Thanks.
Old Jan 11, 2006 | 08:55 PM
rkd's Avatar
rkd
My 82 Bronco did exactly this until I learned that it took 6 quarts of oil instead of 5.
Annoyed the daylights out of me for a year. After that, it used a lot less.....
Old Jan 11, 2006 | 09:09 PM
zapster's Avatar
put it down as "its getting broken in"
engines "useing" or "loosing" oil without leaving drips and such is not a big deal
thats just the way it is
thats why they say to check your oil with every fill-up
...zap!
