NPI P&P Heads
Old Jan 10, 2006 | 08:24 PM
Bartak1's Avatar
NPI P&P Heads
Ive been searching for a few days, but cant find anything. Im looking for a pair of NON PI ported and polished cylinder heads. Doesnt anyone sell these? Everyone has the PI ones, but Id rather not have the PI's because at this time I dont want to have to run 93 octane, and I dont want to change out the pistons at this time to lower the CR so I can run 87 octane.
I plan on getting a pair, along with some .550 or .600 lift cams, or maybe just stick in some PI cams. Hopefully it'll give me a nice little boost along with ported intake manifold, elbow, TB, and tune.
If no one sells these, are there any good places I can send a set of NPI's and have them P&P'd (that's not to pricey either)?
Thanks for the info!
Old Jan 11, 2006 | 03:41 AM
azreael344's Avatar
Ported NPI Heads
Nobody I know of sells ported NPI's but there is a machine shop they rave about on www.tccoa.com for porting NPI heads. Do a search over there and find the contact info for them. But why do you wanna stay NPI? I know for a fact you can get more flow from a NPI head than you can a PI, the design of the casting allows you to open them up more than you can a PI..........but its not that big of a difference. At least with the PI heads on NPI internals you get a compression bump.
Old Jan 11, 2006 | 01:23 PM
Bartak1's Avatar
Hey,
Thanks for the link, Im checking that out right now.
Main reason I want to stay NPI is because I dont want torun premium right now, and dont want to put in the dished pistons required to keep the CR down when you go to PI's-if your not wanting to run premium gas that is. Plus, P&P'd NPI's can actually outflow PI's (with the right P&P job and cams). Another reason-you can pick up NPI heads on ebay for under 100 bucks. PI heads go for over 600 bucks.
If I had another block to work that was out of the truck, and money permited, Id be doing this differently. Im trying to get away w/o pullin the engine, minimal down time, and least expensive for the time being
Found the place you were talking about I think. Renegade.
Old Jan 11, 2006 | 01:55 PM
azreael344's Avatar
renegade yep........... but your truck is a 99............your truck should already have PI heads shouldn't it. if it is then going to NPI's on a PI block will drop your compression. And you're right, and i even said it, NPI's can me made to outflow PI's but the difference is minimal.
Old Jan 11, 2006 | 03:44 PM
Bartak1's Avatar
I have a 4.6, which didnt get the PI's till 01. The 5.4's got the PI's in 99 though.
Old Jan 11, 2006 | 03:52 PM
azreael344's Avatar
well as an alternative to sending your heads out to renegade look on www.modulardepot.com or one of the mustang forums like corral or stangnet for a set of SVO heads. basically they are NPI heads with a stage 2 port
Old Jan 11, 2006 | 04:59 PM
Faster150's Avatar
hehe ur just jealous cause i got some NPI's and u dont!! but yeh.. www.portpros.com
is the company whome i bought the heads from.. only i got em for 482 not... twice that
Old Jan 16, 2006 | 07:07 PM
RI995.4L's Avatar
Check out Steen Racing
Jason is on the ball. I have a 99 Superduty I will be doing this myself soon.
Jon
Old Jan 16, 2006 | 09:13 PM
Bartak1's Avatar
Thanks for the link. Looks nice and affordable, I just wish those were bigger flow numbers. If you get a before and after dyno run comparing them to stock, you should post the results.
Thanks!
Old Jan 16, 2006 | 10:27 PM
Faster150's Avatar
nice lookin truck bartaki i like that all black look!!
Old Jan 16, 2006 | 10:45 PM
Bartak1's Avatar
Thanks Faster!
Old Jan 21, 2006 | 08:06 AM
RI995.4L's Avatar
Thanks!
Jason will accommodate ....just ask
Old Jan 21, 2006 | 01:52 PM
Bartak1's Avatar
Awsome, Ill have to email him. Thanks.
