sound diagnosis
Old Dec 31, 2005 | 09:09 PM
huntingnfishing's Avatar
Originally Posted by NKENN
A couple of months ago I needed some MERCON Power Steering Fluid (PSF)and wondered why MERCON Automatic Transimssion Fluid (ATF) wouldn't work. I called the local dealership and the parts dept. advised me to use the MERCON PSF. I sent my wife to the dealership to buy some PSF and when she got there they didn't have any. Then they asked a mechanic what they used and he told my wife and the parts people that they use ATF. He told them that it is the same thing except that the ATF is thicker and operates quieter in the power steering pumps. I used the MERCON ATF. I didn't have a noise problem and I cannot vouch for the validity of what the mechanic said, just passing it along as information. If you are absolutely sure the noise is coming from the power steering pump, you could drain the system and replace the fluid with MERCON ATF and see what happens. It will only cost you a couple of bucks to try. I had a problem with a noisey power steering system once on a Ford vehicle under warranty and the dealership overfilled the reservoir slightly to alleviate the problem. Also, it has been my experience that alternators make a whining noise in certain failure modes.
My owners manual states to use ATF fluid in the power steering pump..... Also I believe that Ford Power Steering pumps are just downright notorious for being loud.
Old Jan 1, 2006 | 02:33 AM
fordmuscle385's Avatar
you can hear it at idle, its not loud but you can hear it if you listen. it really wails accelerating from a stop.
Old Jan 2, 2006 | 11:14 AM
mountaineer02v8's Avatar
[QUOTE]
Originally Posted by mountaineer02v8
If the power stearing fluid is over filled it might be making a whinning noise??
I have no idea why but my power stearing fluid is WAY past it's full mark, almost to the point where if you take the lid of it might over flow a little bit. QUOTE]
alright, so after reading this thread and hearing about a whinning sound that is coming from my engine as well that didn't bother me to much since it wasn't to loud, but know my power steering fluid was way past the full mark.
I went out yesterday with a small bottle and sucked out enough fluid where it's between the MIN and MAX mark, I also noticed how brown (like dirl fluid) the fluid was. I don't know what power steering fluid should look like, but it's really ugly brown??
Anyway, to make a long story short, after taking fluid out, the whine is GONE! I couldn't believe it myself, but after driving a little over an hour yesterday I never heard the whine like I normally do with the window down!
Old Jan 2, 2006 | 06:48 PM
thats odd......I reckon i'll mess around with mine tomorrow. mines just below MAX. i might change the fluid see what happens.
Old Jan 3, 2006 | 01:24 PM
Wheres the best place to drain the fluid from the system? I see hoses running to the power steering cooler looks like the lowest point, is there an Oring or anyhting there that I will have to replace if i lossen it? How many quarts of Mercon will I need?
Old Jan 3, 2006 | 06:07 PM
raisin's Avatar
You could use a turkey baster to suck up fluid after removing the cover. You could do this several times and get most of it. I believe the carbon vanes in the pump turn the fluid black.
Old Jan 3, 2006 | 07:19 PM
pull the fluid out, fill the resevoir, run and repeat?
Old Jan 4, 2006 | 12:38 AM
Sparky604's Avatar
this is the first time i've ever heard of anyone changing their power steering fluid for the sole reason of changing the fluid and not actually having any problems with it.
Old Jan 4, 2006 | 08:12 AM
look, it sounds like a little car driving in reverse when i drive down the road. It really bothers me. I'm just trying to see if I cant quieten it any......
Old Jan 5, 2006 | 06:15 PM
could there be air in the system? I've pulled and replaced w/ Mercon ATF sound still remains... , i know the dealerships gonna charge me out the *** just to look at it. I'm trying to narrow it down.
