RPMs at highway speed
Old Dec 4, 2005 | 02:45 PM
Thelt's Avatar
How many RPMs do you typically turn at highway speeds? I am running about 2500 at 55 mph. I guess that is not too high but it feels like the truck is straining to keep up that speed. Maybe I am just used to having overdrive.
Old Dec 4, 2005 | 03:02 PM
wetanner's Avatar
That to me seems fast, my 2000 xlt 4X4 5.4 4r70 3.73 with 265/70R/17s at 55 mph is doing 1500 to 1600 RPMs
Old Dec 4, 2005 | 03:07 PM
LittleTow's Avatar
Thelt, what are the specs for your vehicle? Do you have overdrive & is it turned off?
Old Dec 4, 2005 | 03:13 PM
ian51279's Avatar
I never run that slow. I have an 05 4x4 with auto and 3.73 rear. It runs at 2k at 70
Old Dec 4, 2005 | 03:16 PM
Anchorman's Avatar
Thats too high for 55 MPH... WAAAY more than any vehicle I've owned, at 55 MPH I'm around 14-1500 rpm
Old Dec 4, 2005 | 03:30 PM
ECG : Blindman's Avatar
Talking
1000 rpm to 3500 rpm.
Old Dec 4, 2005 | 03:41 PM
fordmuscle385's Avatar
I turn 2 grand at 70 with a 4.6. make sure the little overdrive light on the shifter lever is not lit.
Old Dec 4, 2005 | 03:44 PM
Red00Lariat's Avatar
I run 1900 at 70mph with 3.55s and 265/70R17 tires. Make sure the O/D light is off, if it is blinking then you have a trans problem.
Old Dec 4, 2005 | 04:06 PM
usedtodrivechev's Avatar
way to high
i run 2,000 at 70-75..
94 f150 351 E4OD 3:55, 235/75r15
Old Dec 4, 2005 | 08:17 PM
expy03's Avatar
You didn't say but I assume you have an older vehicle without overdrive, and depending on the rear gears, 2500 at 55 is not bad.
What year do you have?
Old Dec 4, 2005 | 08:27 PM
Serpent30's Avatar
Mine turns just a hair under 2,000 rpm at 70 mph.
Mine turns about 2500 in 3rd gear at 55 mph. It sounds to me like your truck isnt shifting into O/D.
Old Dec 5, 2005 | 06:14 AM
wetanner's Avatar
I lied, I said I ran about 1500-1600 @55. Last night going home I checked, more like 1400 RPMs
Old Dec 5, 2005 | 08:49 AM
Thelt's Avatar
I guess I should have gave my specs in the first post, sorry. It is an '89 F150 with a C6 three speed and a 351 V8. It may just be me, I have not driven a car without overdrive in a long time before I got this truck.
Old Dec 5, 2005 | 09:26 AM
LittleTow's Avatar
Hi Thelt - souds fine to me depending on your gearing & tires, is there anyone else here with his set-up?
Old Dec 5, 2005 | 09:37 AM
Podunk's Avatar
If hes only got 4:11 rears, thats about right for a 3 speed.
My 2000 Ranger had 4:11's and it turned 2200 at 60mph in overdrive.
