Temp Gauge Probe ( Coolant ) Help?
Im looking to purchase a Ford Racing water temp gauge and oil pressure gauge for a pillar pod. Im using the far right front corner manifold plug for the temp gauge im using right now. Is that ok, or is there a better location thats more accurate. I was told to find a T-Stat Neck with the top made to take a sensor. Does anyone make one of those and is that really the best location.
ALSO , Where's the best place to find a Pillar Pod that matches the light gray interior for F-150's ?
Some education would be much Appreciated !! :santa:
I use the same right front manifold tap for my guage and it is dead on to the temp sent to the PCM (based on datalogging) To me, dead on is close enough.
The pillar pods don't come pre-colored to my knowledge. Autometer makes a pretty good line of them. They look good when painted and properly installed. Take a look:
[IMG][/IMG]
[IMG][/IMG]
I put a tap in the heater hose on the water pump outlet for my temp gauge. Unfortunately I haven't got those pics up in my gallery but if you are interested I could dig them up. I did it without cutting the hose by just adding a piece from another molded hose I had laying around. Works great. You can watch the thermostat open and close and when at temp it is right on at 195 right where it should be.
As far as the pilar pods can't help there I didn't go that route.
