Code P0153 - How to change sensor
I have a 99 F150 XL that is giving me a code PO153, which from other posts I've read is a bad o2 sensor on the drivers side. I've also read that they are pretty easy to change. Can someone lead me to a picture, or even just tell me where under the hood the sensor is located, and the simple steps to change it out??
thanks
Randy
thanks
Randy
It's not really under the hood. There are 4 02 sensors. They're screwed into the exhaust pipes. 1 before and 1 after the cats on each side. You can access the upstream one through the wheel well and the downstream from underneath the truck. You'll need a special O2 sensor socket and you're better off letting the engine warm up some before trying to remove them, or you'll have a hell of a time getting them off.
