Oil Separator ?
Old Oct 4, 2005 | 01:11 AM
Tuff4rd's Avatar
Oil Separator ?
Found this item at Ebay, anyone know if this thing is worth getting?
THANKS
http://cgi.ebay.com/ebaymotors/Oil-S...04426981QQrdZ1
Old Oct 4, 2005 | 01:32 AM
02SuperCrew4X's Avatar
Just send me the $32.00 you would pay for that thing, and I will send you an empty box. That's about what that thing is worth. Oil separator..pfft.
Old Oct 4, 2005 | 07:25 AM
KingVinnie's Avatar
You dont need that. Its for Supercharged motors, to keep them from sucking oil in the intake at high boost. They do work well 02SuperCrew4X, and are a must for anyone with a SC Harley or Lighning. I use to have to empty mine once a week.
Old Oct 4, 2005 | 05:10 PM
Redroush98's Avatar
It actually isn't a bad idea, it goes between your intake manifold and the PCV valve. When oil gets hot it releases gasses as it expands. Those gasses are routed throught the PCV valve and into the intake manifold where they are burned in the cylinders. The problem is when the gasses go through the PCV valve they take all kinds of nasty gunky black crap with them. If you have ever pulled an intake apart and looked at the inside it's covered with nasty crap. This comes from the pcv valve. The oil filtration system keeps a good amount of that stuff out.
But don't buy that it's just an inline water seperator for an air-compressor, you can get it cheaper at home depot or whatever. A cheaper way is to put one of those cheap kragen fuel filters in the line. I installed one of those cheap fuel filters in my protege after I ported and polsihed the intake manifold and it has done a good job of keeping the crap out.
Old Oct 4, 2005 | 06:31 PM
Faster150's Avatar
18 bucks for it all from walmart
it works best if u remove the filter.. dunno how i think it deals with vacume but after a week of havinf the filter in it start sucking oil past the filter so i removed it advice from someone with a stang he said he catches more oil if its removed so i removed it and checked the next day and it was 1/8th full
