couple of HP questions
Old Sep 25, 2005 | 03:11 PM
liftITupHIGH's Avatar
Does anyone know if you can use a 75mm throttle body from a 4.6L mustang on a 97 f150 4.6L? Can a throttle body spacer also work with this?
Does anyone know if the intake tornado thing actually works or is it a waste of money?
Old Sep 25, 2005 | 03:55 PM
jhoparmy's Avatar
I don't know about using the Mustang throttle body, but I do know that both the throttle body spacer and that tornado thing are a waste of money. If you want performance upgrades talk to Mike Troyer @ troyerperformance.com, he can steer you in the right direction. Hope this helps.
Old Sep 25, 2005 | 06:44 PM
The ad says that it gives you 35 hp is that just a lie?
Old Sep 25, 2005 | 06:56 PM
JerseyGeorge's Avatar
If it's sounds to good to be true.........IT"S BS!
Old Sep 25, 2005 | 07:15 PM
Neal's Avatar
HI!... If you mean a MUSTANG TB is 75mm? It's not. It's 70mm just like the ones on the F-150 4.6/5.4.
Old Sep 25, 2005 | 08:26 PM
Sorry about that I meant an aftermarket 75mm like a BBK. A larger one.
Old Sep 25, 2005 | 09:15 PM
Faster150's Avatar
the linkage is reversed.. on the mustang.. it pulls from behind not the front.. while yes it will work... its just going to be interesting re routing the throttle cable around behind
Old Sep 25, 2005 | 09:23 PM
Well thats what i need to know. Do yuo know were I can get a larger one for an f150
Old Sep 25, 2005 | 10:45 PM
Neal's Avatar
HI!... BBK makes a 75mm TB for the F-150. I got mine from MIKE TROYER at TROYER PERFORMANCE. He goes as Superchips Distributor in the computer chips section.
