Best Plugs?
Old Sep 19, 2005 | 09:10 PM
pa98tj's Avatar
Question Best Plugs?
i have a 99 f150 4.6 4x4 extended cab short bed. it has 82 thousand miles and i just bought a new set of ford motorsport 9mm plug wires and i am wondering which plugs would go best for my application. which ones perform the best and about how much do they cost.
thanks
jesse
Old Sep 19, 2005 | 09:20 PM
jjmIII's Avatar
Motorcraft or Autolite double platinum's
Old Sep 19, 2005 | 11:53 PM
Red00Lariat's Avatar
Motorcraft stuff tends to be pretty good. Autolite and NGK is good too. If you want top of the line then get some Denso Iridiums.
Old Sep 20, 2005 | 12:09 AM
98Navi's Avatar
If you aren't running anything performace wise, then you'd be wasting money adding expensive plugs. I run the Iridiums, and they are like $100 and up a set of 8. Platinum is the factory plug, but platinum is a rather poor conductor and I would slide in some copper plugs. But, again, without a lot of mods anything other than stock is a waste of money
Old Sep 20, 2005 | 12:40 AM
6T6CPE's Avatar
I just installed NGK Iridiums yesterday with some new 9mm wires and Accel coil packs. I haven't fired it up yet. I still have to put on a new belt, hoses and thermostat. 140,000 miles and this will be the second set of wires and plugs I put in. I had a misfire on cylinder 3. All 8 old plugs looked real good. I'm a big believer in synthetic oil. I use Amsoil or Mobil 1. Baldwin oil filters.
