IAC Location???
Old Sep 18, 2005 | 02:18 PM
Faster150's Avatar
Originally Posted by Johngs
Apparently.
I've taken that TB apart, there is no hose going to the IAC.
So yes, please explain what you are talking about.
the hose that feeds the air to the IAC. its not directly connected to the IAC its built into the plenum. but its only purpose is a air bypass for the IAC. i was saying to red rousch if he doesnt want to remove it just remove that hose from the intake and spray the cleaner in there while the engine is idling and it will clean the IAC out pretty good. same with throttle body crack it open some engine will usually run up to 3,000 RPM spray the cleaner in there if u wanna clean the whole intake system including backs of valves
and clean any gunk off injectors.
